Page 1 of 2
2004 silverado z71- whats the best tune
Posted: Sat Sep 27, 2008 1:32 pm
by possum07
I have a 2004 Chevrolet Silverado z71 with a vortec 5.3 . i just bought a brand new U7193 and i am wondering what all i need to adjust to get the most power out of. example i did the diablo tune but i dont feel much difference in acceleration what would i do to change that? And any other changes i would need to do?
RE: 2004 silverado z71- whats the best tune
Posted: Sat Sep 27, 2008 2:05 pm
by 06MonteSS
what octane gas are you using?
also, you'll want to get your fueling dialed in correctly...
Posted: Sat Sep 27, 2008 2:27 pm
by CANUCKPREDATOR
it also takes 30-50 miles for the truck to relearn with the new program. you may not feel a difference right away.
Posted: Sat Sep 27, 2008 4:14 pm
by possum07
im runnin 93, and how would i do that
Posted: Sat Sep 27, 2008 4:42 pm
by CANUCKPREDATOR
read the link monte provided
Posted: Sat Sep 27, 2008 10:25 pm
by Grumpy_Aero_Guy
As it says in the post, you'll need this:
http://www.dslogredux.com
Posted: Wed Oct 01, 2008 4:37 pm
by 04z71
alright bro i'll help you out since we have the same truck.
performance tune with 93 octane
injector slope -7
adjust the shift quickness so it shifts faster
adjust for gears
adjust for tire size
i can't think of anything else right now but i'll see if i have anything else done
Posted: Wed Oct 01, 2008 4:41 pm
by 04z71
also turn off the first two torque managment settings and leave the last one on
i also have an intake an duals so it might be a little different for you
Posted: Wed Oct 01, 2008 5:52 pm
by CANUCKPREDATOR
you CAN'T share fueling information. no two motors run the same. you HAVE to log for YOUR vehicle and make adjustments for YOUR vehicle.
Example: my fuel adjustment is -2
Posted: Thu Oct 02, 2008 11:16 am
by 04z71
right but it was more of like a guide line. He should be able to set his own slope. It's not that hard
Posted: Sat Oct 11, 2008 6:03 pm
by possum07
Ok i did my logging an it said to adjust injector +2 so i did. whats next??
Posted: Sat Oct 11, 2008 7:58 pm
by CANUCKPREDATOR
Drive 30-50 miles log again just to make sure. Try to log in the same weather as that can effect your results, use the same road too.
Posted: Thu Dec 11, 2008 9:38 pm
by possum07
sorry it's been so long guys, i just haven't gotten around to tuning yet because it turned off cold here so im thinkn bout waitin till spring to finish getting the right setup but I havent forgotten about you guys, because your info is so valuable but im lookin forward to it. I aint winning that many drags with what its set on because the fueling is still of i think thats why im wating till warmer weather.
Posted: Mon Mar 09, 2009 10:56 pm
by possum07
i have did the log 3 times and it has said the same thing everytime I install it to dslogredux which is that my injector slope needs to be +2% and i changed it to what it said but nothing changed when i ran another log and loaded it back to dslogredux everytime. do i need to save the files or need to delete the old one off the programmer it self and if so how do I do that?
Posted: Tue Mar 10, 2009 7:56 am
by 06MonteSS
you hook up to your truck, select the same tune you installed before, select Modify Tune, scroll down to and select Fuel Injectors, then select injector slope, change it to +2%, press the center button to save the change, then press the ESC button a couple times to back out until it asks you "install tune now?" - select YES and it will install the change...
sounds like maybe after making the adjustment that you didn't press the center button to save the change...
when you go back into the modify tune menu for the injector slope, does it have an asterisk next to it?? that indicates that it's been changed...
