bad tuner?
Posted: Sun Sep 28, 2008 4:10 am
by 4.10GT
My car was running 14.6-14.9 with 4.10 gears modded H-pipe flowmasters and a TB then i changed the IAC valve and i went to the track this saturday and ran a 14.3-14.6. I was running unconsistant and top end sorda seemed to fade out and i figured i should be in the 13's with all of this so i put on my stock tune with the same modded parameters and went again today and ran consistant 14.0 this is on my stock tune is my perfomance tune for my tuner messed up because i feel no power difference from my stock tune to the performance tune the stock actually feels faster!?
RE: bad tuner?
Posted: Sun Sep 28, 2008 8:55 pm
What were the trap speeds?
MPH is the best judge iof additional power, and often ET will suffer due to wheelspin from extra power...
RE: bad tuner?
Posted: Mon Sep 29, 2008 1:41 am
by 4.10GT
with tuner was around 96 and with stock tune it was 98 it just feels slower with the performance tune too.
RE: bad tuner?
Posted: Mon Sep 29, 2008 1:47 pm
by 4.10GT
anyone? i paid 400 dollers for this so i would like it to work.
RE: bad tuner?
Posted: Mon Sep 29, 2008 2:14 pm
by 4.10GT
btw my car is a 99 mustang gt auto and the tuner is U7146 also have time slips to prove it.
RE: bad tuner?
Posted: Mon Sep 29, 2008 2:40 pm
My guess is that you have changed something on the car that is causing it to not run ideally with the performance tune, may be time for some fine tuning on the dyno or even a custom tune...
RE: bad tuner?
Posted: Fri Oct 10, 2008 2:18 am
by 4.10GT
Alright so i put the performance tune on tonight and decided to go into WOT fuel and lean it and move it to 0.50 i did it for both and i seem to notice a difference now is this going to hurt my car? im gonna run it friday to see if i run at faster time like this.
RE: bad tuner?
Posted: Fri Oct 10, 2008 10:14 am
Leaning anything out without knowing hwere you are to start can be scary....look into some dyno time or a wideband.
RE: bad tuner?
Posted: Fri Oct 10, 2008 12:07 pm
by 4.10GT
o i just leaned it one notch from stock seemed alot faster but i took the tune off right when i got done and put the stock tune back on. could it hurt it that much? because there isnt a dyno near here and i dont see why my tuner makes my car slower.
Posted: Sat Oct 11, 2008 1:12 pm
by 4648
Try lowering your shift pressures back to stock.
I was running 13.6-13.7 at 101-102 mph in my mildly modded 2001 mustang gt.
I knew it had more in it because 2 years ago I ran a [email protected] mph, and was trying everything to find the lost power. finally I lowered the shift pressures back to stock and now most of my runs are 13.4's @103+ mph. New best of 13.415.
I have done the J-mod to the tranny to improve shifts. Check out Tccoa.com for more info on the J-mod.
Posted: Sat Oct 11, 2008 2:07 pm
by 4.10GT
ive never adjusted the shift pressures but thanks tho! the weird thing is my MPH is only 98
Posted: Sat Oct 11, 2008 7:05 pm
by crono2120
I'd take Mikel's advice, put it on a dyno. You don't know what the diablo tune is doing let alone how customizing is going to affect it. Trial and error might just prove more costly than you'd like.
Posted: Sun Oct 12, 2008 2:51 pm
by 4.10GT
no dynos around here closest is dyno chips and the 3 hours away
