Help Duramax problem
Posted: Thu Apr 19, 2007 9:55 pm
by cuffnup
Coming back from a trip to florida which i drove down stock...thought i would drive back in the 40 or 65 horse to see a diff. in gas milage..programmed the truck and nothing worked..speed was showing about 65 but i know i was at least 80...and both brake lights came on and the brakes wouldnt work right...abs and emergency brake dummy lights that is ....had to pull over and put it back to stock...now its fine... any bright ideas.....i have used the preditor for a while and the only real problem i have had was with it surging while driving ...which this problem has never been addressed...now this problem...which makes it impossible to drive..what do the experts think
RE: Help Duramax problem
Posted: Fri Apr 20, 2007 8:12 am
by johan
What part number is this?
Posted: Fri Apr 20, 2007 9:26 am
Is this a new problem, as in the unit worked in the truck previously?
Have you changed the wheel/tire size?
If so, did you change the settings in the Predator?
U7186 06 LLY
Posted: Fri Apr 20, 2007 11:04 pm
by cuffnup
the dealer installed a new cluster...it has worked before but had some surging at some speeds...if they reflashed it why would my brakes and lights ack up and speedometer not work...It is a U7186,,,2006 duramax LLY
RE: U7186 06 LLY
Posted: Fri Apr 20, 2007 11:12 pm
Can you please post the revision on this tool.
Posted: Mon Apr 23, 2007 10:11 pm
by cuffnup
It is the 1R17...
Posted: Mon Apr 23, 2007 11:22 pm
We addressed an issue in the 1r17 revision where changing the tire size would cause those issues.
Please update to the latest revision to cure this problem.
Posted: Tue Apr 24, 2007 9:39 pm
by cuffnup
I must say i am very sorry...i had to dig on your website to find it but i did...i kept on looking on the front page for the latest updates..now the truck is okay except for the little hesitation but it is not major...if you ever get a chance to test and fix it let me know...thanks
