Not Licensed for use with this vehicle
JohnEagle
Post by JohnEagle »
U7158
v.8R10
2000 For Lightning
Calid MRAD3K5
Shows my VIN
I bought this unit used from a fellow "L" owner. The unit is an older one ( says 11/11/2005) as I can not DL the newest update. It goes to a blank screen and doesn't do anything with the newest update installed. But that's not why I am posting.
When I try to load a tune onto my truck is says " Tool not licensed for use with this vehicle.It says last tuned written... Factory HP Tune. I assume that means it is unlocked? Any help would be awesome.
John
RE: Not Licensed for use with this vehicle
sounds like it's locked to the original truck still...
it should say original backup as last tune written if it was unlocked...
lazorrazor
Post by lazorrazor »
you have a locked tool, you need to get hold of the seller...
LaZoRRaZoR
VegasMongoose
Post by VegasMongoose »
I was the original owner. He shipped it back to me and I plugged it in. I thought I had downloaded the stock tune before I sent it out, but when I plugged it in, it said 91 performance tune. So now that I downloaded the factory HP tune, it should be good to go, right?
crono2120
Post by crono2120 »
I think there's a selection in the options menu to restore factory tune. Not positive. If you can hold off for an answer from Diablo I'd do it, no need to waste shipping.
JohnEagle
Post by JohnEagle »
Thanks Vegas! Hopefully someone will chime in and confirm.
lazorrazor
VegasMongoose .....
Yes, should be good to go, as long as you restored factory tune new owner will be able to use it...
LaZoRRaZoR
JohnEagle
Post by JohnEagle »
Thanks for the reply Laz.
Would someone from Diablo please confirm this?
John
kmac1
Re: RE: Not Licensed for use with this vehicle
Post by kmac1 »
JohnEagle wrote:Thanks for the reply Laz.
John
Make sure you "Restore Original Backup" on the truck it is locked to. The "Factory HP tune" is not the stock tune and will not unlock the Predator. It is a basic tune that is prepared for modification by the end user. "Restore Original Backup" can be found in Options, Troubleshooting.
Kevin@Diablo
JohnEagle
RE: Re: RE: Not Licensed for use with this vehicle
Post by JohnEagle »
Thank you Kevin.
VegasMongoose
Thanks Kevin, I appreciate the help. John, I will do that tomorrow and get it shipped back to you ASAP. Thanks again everyone.
Return to “Predator Ford Gas”
