there is a section entitled:
Torque Management
PLEASE NOTE: Disabling torque management will put greater stress on your drive line.
* TM Abuse Mode time limit:
This is the time in abuse mode as a function of temperature. Turning it off in conjunction with Upshift Torque reduction and %Torque Reduction vs RPM will eliminate torque management.
* %Torque Reduction vs RPM:
Torque reduction as a function of RPM, turning it off in conjunction with TM abuse mode time limit and upshift torque reduction will eliminate torque management.
* Upshift Torque reduction:
Torque reduction control for each individual gear, turning it off in conjunction with TM abuse mode time limit and %Torque Reduction vs RPM will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
I see no such things under Torque management on my 9r05 7198.
The car is an 02 Corvette, automatic.
Now what?
Thank you.
Under the sticky titled: "Adjustable parameters explai
RE: Under the sticky titled: "Adjustable parameters ex
There is now one parameter which is all thats left on in the tune, if you want TM disabled, turn this last parameter off.
Huh? I've not a CLUE what that means.
it means, that there is no longer the 3 separate TM settings to adjust... they have disabled the other 2 in the tune already...
so, you will only have 1 TM setting available... if you want TM totally disabled, turn that single parameter off / disable it.
firefighter698
