Need helping with data logging!
04SERPENT
Post by 04SERPENT »
I currently have the 7r12d 03-04 Cobra model. I am trying to send my data logged file to my PC. The only problem is that I'm missing the "real time streaming" from my unit! How am I to transfer my log to the CMR-Data without it? Is there an upgrade I can do?
kmac1
RE: Need helping with data logging!
Post by kmac1 »
You need to use the old DAT viewer program to upload logs. When you open the program it will say communicating, click cancel on that. Go into tools, get log file from Predator, then name your log. Now go into Options, Troubleshooting on the Predator and hit log upload. The Predator will now begin to communicate, this is when you hit save in the software and the log should upload to your PC. Make sure you have the correct baud rate(57600) and the correct com port selected. Now that you have it uploaded you can view it in either DAT Viewer or the newer version of DataViewer.
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
Return to “DataViewer/DV2”
