torque source logging
This section of the forum is for discussion relating to the T2 tuner/monitor on Ford vehicles.
WildHorse
Post by WildHorse »
how do I get this to log torque source ?
Need to see the DD torque correcting. I just need to make sure driver request torque is above what torque its calculating from the WOT airflow. my problem I'm fighting right now with your guys tune, when the slicks go on, clutch protection kicks in big time, almost like the brakes are being slammed on the initial hit & on the 1-2 and 2-3 shift.
Gʀᴀʙʙᴇʀ Bʟᴜᴇ 2017 Mᴜsᴛᴀɴɢ GT 300A -- SOLD
Re: torque source logging
I thought that was worked out in the tune, or did the issue reappear when you added the slicks?
WildHorse
Post by WildHorse »
mikel wrote: Mon Jun 10, 2024 10:48 am I thought that was worked out in the tune, or did the issue reappear when you added the slicks?
Yes Sir.. when the slicks went on, like a slap in the face .
got a log of it with the slicks by chance?
WildHorse
Post by WildHorse »
mikel wrote: Thu Jun 20, 2024 10:30 am got a log of it with the slicks by chance?
I did , but my laptop had a hard crash unfortunately. . I remember the very first tune you guys sent me, that one worked like a charm, but again lost it when my laptop died :(
WildHorse wrote: Thu Jun 20, 2024 7:30 pm
this is the very first file i sent you back on 9/27/21....I have them all....there were quite a few :)
WildHorse
Post by WildHorse »
Right on, thanks !
WildHorse
Post by WildHorse »
Sooooo that tune was adding 20% fuel. So I figure it was configured for the 86mm MAF. I upped it via the T2 in the adjust settings section, to 16% (for the 99.7mm MAF), however the T2 displayed 20% in the confirm section. Dunno why. Started it, went for a test drive, 0-2% STFT now which is good. So my question is, good to go now ?
will look into the difference between what you entered and what it confirmed for sure, but yes, as long as the trims are settled and stick around there, it should be good to go.
WildHorse
Post by WildHorse »
mikel wrote: Thu Aug 08, 2024 2:54 pm will look into the difference between what you entered and what it confirmed for sure, but yes, as long as the trims are settled and stick around there, it should be good to go.
Thanks. In the meantime, found the 2018+ airbox tune. Went for a rip. I suggest you take a look at this log and it's the reason why I was a little upset ha-ha.
WildHorse
Post by WildHorse »
10 days later ... confirmed good to go ? Got this on the 24th.
I submitted a ticket for the team to investigate the display vs entry issue, I'm sure its fixed, will follow up with them now.
WildHorse
Post by WildHorse »
mikel wrote: Wed Aug 21, 2024 9:36 am I submitted a ticket for the team to investigate the display vs entry issue, I'm sure its fixed, will follow up with them now.
Fantastic.
WildHorse
Post by WildHorse »
What the word on this ?
firmware changes get moved through a test cycle, and don't get pushed live until everything they are testing is good, hopefully not long
Return to “T2 for Ford”
