U7164
9r03
08 F250
Try to update tuner for customer, only file for U7164 is 9r04_export.crom. When try to load get following message on Predator, "cannot load CRYFG109 aplication into U7164 tool."
Messages when programming are Unit #1(8U7A-14c204-FA)
Unit #2 (8C3A-14C337-CA)
What can we do?
U7164 Update!
RE: U7164 Update!
Are you using "Send Tune" instead of "Send CROM"? See the DS Downloader Help file under "Updating the Software CROM".
johnc <at> diablosport.com
chromedome
RE: U7164 Update!
No, using send crom. Done this several times before but never has "export" been in file name.
RE: U7164 Update!
What version of DS Downloader are you using? You should be using 1.9.9.6.
Also, try using the "To re-configure communications for a specific tool, click HERE" link on the first tab before you connect the Predator to your PC.
