Is fuse removal necessary to program?
ddd269
Post by ddd269 »
I have a 2007 Yukon Denali and was wondering if taking the fuse out is really necessary. I've installed the program from the beginning without removing the fuse and was wondering if this affects anything.
Thanks.
Grumpy_Aero_Guy
RE: Is fuse removal necessary to program?
Post by Grumpy_Aero_Guy »
I have gotten "lazy" and haven't been pulling the fuses either, thus far with no apparent ill effects.
Now, the manual clearly states to REMOVE the fuse. I DO know that any electrical draw on the system during a tune process can interrupt/corrupt the process.
I guess we are performing at what appears to be a slight risk. It would probably be best to pull them all --- but I haven't had any ill effects to date (at least 20-30 tune operations so far)
DSLogRedux.com
if you have any aftermarket items installed - anything that didn't come stock on your vehicle, you HAVE to totally disable them, pull their fuses, etc.
if you're totally stock but have onstar, you have to pull the onstar fuse... if there's communication to/from onstar during the tune write process, it could cause a failure.
if you don't have onstar, and don't have any aftermarket items installed, then no, you don't have to pull any fuses.
racerx55
Post by racerx55 »
i dont have onstar activated, but the truck has it,and bose stereo. i dont pull fuses, its been fine so far. and ive actually flashed the ecu with the key on acc. not "on" and it worked, now i did notice having HID's and leaving them on will definately cause some problems.
93 Talon Tsi AWD - 10.89@128 - 28 psi ECM link
93 Laser RS AWD - 12.97 @ 104
91 Talon dirt circle track car
05 Silverado Z71 HO 5.3 "B" - predator U7193
johan
Post by johan »
Only thing necessary to pull on the NBS truck SUV is the navigation system if equipped with one.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
ddd269
Post by ddd269 »
ty guys!
2007 Yukon Denali
Volant CAI, Volant Exhaust
sickREDsierra
Post by sickREDsierra »
i always had to pull my "radio" and "radio amp" fuses.
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
turbojamie
Post by turbojamie »
My uncle was playing the game on a 2008 silverado Duramax with a PPE programmer and didn't pull the fuses it toasted the ECU had to tow it to the dealer, luckily one of my best friends is the service manager kept his warranty for him and got his ECU under warranty.
PULL the fuses, it takes what a minute tops and is cheap insurance. The duramax ECU isn't bad to purchase around 400 bucks canadian but its not worth it.
bosro
Post by bosro »
Just saw this thread.
Since I've had the Predator I have been pulling the fuse for the Onstar system.
I also have the navigation system in my truck.
Never pulled the fuse for it and I am not even sure which fuse it is for the nav system.
Don't have the owners manual handy right now.
Anybody help me out as to which fuse# on the NBS trucks to pull?
Rather be safe than sorry!
