update for the update
700okie
Post by 700okie »
So are you guys close releasing the update to make the u7164 work properly on the reflashed truck. I still can't run anything but the extreme tune and even then the cruise doesn't work. Would like to know as soon as it is avaiable
joestroo
RE: update for the update
Post by joestroo »
they have been sending me test's, we are super close to getting it right. just i bit more time and we all be good to go!!!!
sohfast94
Post by sohfast94 »
Here's the latest...
I thought I emailed you.
u7164-9t05c_export.crom
(5.58 MiB) Downloaded 171 times
Insert Clever comment here...
700okie
Post by 700okie »
ok I need help, the downloader can't, or won't find my predator. I tried everything I can think of, updating it, reinstalling it, nothing is working
sohfast94
Post by sohfast94 »
No problem.. are your drivers installed for your USB to serial cable?
If so and you haven't restarted your computer after installing the drivers then you will need to so in irder for them to take affect.
700okie
Post by 700okie »
here's what I've got. When I open the DS downloader from the desktop icon it says there is an update avaiable. When I try to update it, a message comes up " an unknown problem has been found with the file download". It will give the option to veiw details, and it gives two errors. One is access denied and the other is download failed. Any ideas, I tried to reboot, that didn't help.
700okie
Post by 700okie »
Ive been jacking with this thing for 3 hours. I finnally got the downloader software to pick up the predator, but now when I try to upload the CROM it says it wouldn't decompress.
sohfast94
Post by sohfast94 »
Geeze what OS do you have? Vista?
700okie
Post by 700okie »
yeah I've got vista. The other CROM files I have seem to work fine. The 9t05c is only one that won't decompress
sohfast94
Post by sohfast94 »
Here use this one...
It should work for you.. This is the latest release...
u7164-9r05_export.crom
(5.58 MiB) Downloaded 156 times
700okie
Post by 700okie »
I know this is probably very irritating for you guys as well but, it didn't work. When I tried the 9r05 crom it pops up freedom and predator not working. This was right after I reloaded the 9t04b crom to make sure it would upload completely, no problems with it. Is this on my end somewhere ???? I'll keep looking. I'll be glad when the puck shows up from the brown truck.
sohfast94
Post by sohfast94 »
Can you do a crtl-prntscrn when it shows you the error so I can see what it says exactly?
700okie
Post by 700okie »
Problem signature:
Problem Event Name: APPCRASH
Application Name: DSDownloader.exe
Application Version: 2.1.0.4
Application Timestamp: 49131c9c
Fault Module Name: DSDownloader.exe
Fault Module Version: 2.1.0.4
Fault Module Timestamp: 49131c9c
Exception Code: c0000005
Exception Offset: 0012bc27
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: e0f5
Additional Information 2: 0600799b0da1891586ed6da0a26652f1
Additional Information 3: ea3b
Additional Information 4: 77a3249e1ca56578dd5cdcf9ff283e56
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
This the problem details pop up hope it helps
700okie
Post by 700okie »
so are you still working on this or is it on my end.
johnc
Post by johnc »
The 7164 croms have multiple sections to be sent to the Predator, and it takes several minutes. You have to make sure you do not unplug the Predator prematurely, as the progress bar will sweep across several times and will appear to stop at a couple of points. Reboot your computer and try again from scratch.
johnc <at> diablosport.com
