Throwing code P0603 when installed
I have a 2003 Excursion 6.0 (S&B intake, MBRP turbo back.....) The problem I am having is this: I took the truck to the dealer to flash the computer; when I tried to reinstall the Predator it would not install reading "vehicle not in database", no problem I updated the programmer to v.9r05. Now when the 100 hp tune is installed the truck throws P0603 powertrain control module Keep Alive Memory (KAM) error. Also when accelerating it will cut out and the pick right back up. And lastly the truck cuts off when I let off while going slow, but will start right back up (has not caused a big problem when out and about). Cal ID: VXAP2A2 U7165 pcm_6_0 v.9r05
Never had any trouble out of previous tunes prior to updating Predator
RE: Throwing code P0603 when installed
Could you send me your last tune written?
Insert Clever comment here...
The prior tune is: v.8r14 which was the tune installed on the predator when purchased
2003 Ford Excursion 6.0L
S & B Intake, MBRP 4" Turbo Back exhaust, DiabloSport Predator U7165
Cal ID: VXAP2A2
I Might Be Slow But I'm Ahead of You
Cal ID: VXAP2A2
When I posted yesterday, I missed a problem. The truck also throws code: P2290 Injector control pressure too low. If I remember correctly this code was also thrown before update. It doesn't seem to cause any problems. Any help would be greatly appreciated.
Cal ID: VXAP2A2
Cal ID: VXAP2A2
A little scatter brained today. The only other problem I am having is the tow/haul button blows out all guages on dash when pushed. I can't see how this would apply to the tuner but I thought I would throw it out there and see what came back.
Cal ID: VXAP2A2
Cal ID: VXAP2A2
Yeah that's definitely a wiring issue... Never heard that one before... check your grounds.
My thoughts exactly. Just have not found the right ground yet.
Cal ID: VXAP2A2
Cal ID: VXAP2A2
Lol the search continues.... I'll dig around see if I can find a diagram of them somewhere...
Re: RE: Throwing code P0603 when installed
Is this the U7165_pcm_6_0-9r05.crom file of the predator that I have installed on the truck now ?sohfast94 wrote:Could you send me your last tune written?
RE: Re: RE: Throwing code P0603 when installed
Yes that's the one.
Email sent with tune attached. Thanks
Cal ID: VXAP2A2
Cal ID: VXAP2A2
Replied. Try that.
Installed; Initially threw P0603, which I cleared. Had a little surge when getting up to speed easy. Seems to have cleared after drive. Will drive for a few days and repost.
Cal ID: VXAP2A2
Cal ID: VXAP2A2
Yeah I saw where it might have surge I though but you hadn't mentioned it so I wasn't going to touch it...
