2001 Bullitt
TheJoker
2001 Bullitt
Post by TheJoker »
Hey guys. I bought a U7146 for my bullitt and it seems to fall on its face until I get up in the rpms. My mods are cold air, under drive pulleys, long tubes, off road exhaust (bassani) and 373 gears. Is there any way that it could have anything to do with the bigger throttle body that came stock on the bullitts? I was just wondering what I could do to fix this. I put back on the stock program and it ran perfect. I used the performance tune. Any help would be great. Thank you very much.
1967 mustang fastback, 2001 Bullitt
RE: 2001 Bullitt
The tunes in the Predator were designed around a stock/mildly modified Bullit. The long tubes combined with the other airflow improvements you've made call for a new custom tune.
Use the 'where to buy' tab above to find a CMR dealer in your area that can tune the car for you on the dyno.
TheJoker
RE: 2001 Bullitt
Post by TheJoker »
Ok so how does that work? I have a dyno scheduled for this Sat? What do I need to get the tune? How much does it cost? I really didnt think that the bolt ons were a big deal until you got into putting cams into the 4.6 and power adders? I mean I cant believe that nobody else has had this same set up to get a close custom tune that you could email out and I could upload.
RE: 2001 Bullitt
The addition of longtubes to almost any vehicle will generally require a custom tune to dial in the combo, as they move the O2 sensors away from the head, which causes driveability and idle problems.
Each and every vehicle will respond differently to these types of mods, so without knowing what the A/F looks like now, we would not know where to start in creating you a new tune. This is why tuning should be done on a dyno with a good tuner so he can interperet the info from the dyno and create a perfect tune for your application.
Pricing is set by each individual dealer.
1999SVT
Post by 1999SVT »
yeah, but with the added amount of air "intake" and "exhaust" it would most likely call for more fuel throughout the powerband;probably in the mid-to-higher rpm's. Obvioulsy the a/f ratio will be slightly higher so a 11-12:1 ratio is somewhere you want to be at wot. Why cant he "modify factory tune" himself with the predator and test from there?
TheJoker
Post by TheJoker »
Ok I had it dynoed. It made 264.76hp and 302.41tq. a/f showed 14.02. Do you have a tune that I can download that will help this out? Or do I still need to pay 150 bucks to get it tuned?
1999SVT
Post by 1999SVT »
omg :shock: 14.2 !!!! ...HOLY-LEAN, BATMAN !!!!! dude, your plugs are probably scorched :!: were these numbers on the original tune or the performance tune?
...why didnt the dyno guys take your predator and start adding fuel to the 2 trim levels? thats most likely where your problem is.
Any detonation heard? What octane were you on?
... low-12's on nitto radials,all motor,all stock internals,all natural-no preservatives
TheJoker
Post by TheJoker »
It was with the performance tune. I would assume that they would have had to charge me 150 bucks if they did anything but dyno it. Looking at the graph right now the temp was 92.02 F and it actually started at almost 16 then went down to about 14.05 at 3500 rpm then about 14 till 4800 rpm then it started dropping to 13.5 from 5100 to 5800 rpm. Not to sure what to do. I cant afford to do the dyno tune right now. I will have to do it next month if they dont have anything I can try.
TheJoker wrote:It was with the performance tune. I would assume that they would have had to charge me 150 bucks if they did anything but dyno it. Looking at the graph right now the temp was 92.02 F and it actually started at almost 16 then went down to about 14.05 at 3500 rpm then about 14 till 4800 rpm then it started dropping to 13.5 from 5100 to 5800 rpm. Not to sure what to do. I cant afford to do the dyno tune right now. I will have to do it next month if they dont have anything I can try.
Go into the Predator and add about 20% to the WOT fuel parameters, maybe even more down low.
This should get you where you need to be.
TheJoker
Post by TheJoker »
Ok I will give it a shot. Thank you very much.
bullitt1668
Post by bullitt1668 »
Joker,
So what was the outcome? Did you add 20% to the WOT? How did it work?
___________________
2001 Kenny Brown Mustang Bullitt # 1668
neckbonekat
Post by neckbonekat »
Hey Joker did you update your predator on this site? Miy Bullitt did the same thing until I updated my predator on this site and it ran much better. I would love to get mine tuned after a few more mods to see what I get.
bullitt1668
Joker and neckbonekat,
How do you like the 3:73 gears vs 4:10's?
email me at [email protected]
Thanks!
2001 Kenny Brown Mustang BULLITT # 1668
Engine:
DiabloSport Predator
Kenny Brown Suspension that also includes an Extreme Chassis Support System also by KB. 1 of 1 Made!!
neckbonekat
bullitt1668 wrote:Joker and neckbonekat,
Thanks!
I've never driven 3.73s. In a couple weeks I will be getting my 4.10s put in though. You guys should come to http://www.moddedmustangs.com there is a lot of knowledge being shared there. It is the only forum I go to where everybody isn't either old or really up tight. LOL
bullitt1668
neckbonekat,
Is your Bullitt a streetroad or a 1/4 monster?
Why 4.10's over 3.73's?
Mine is my dailydriver. I wish it was different, but will have to do for now.
How do you see 4.10's affecting your gas millage?
you can email me instead of replying here at [email protected]
Engine:
Return to “Predator Ford Gas”
