tow/haul mode
trucks2361
tow/haul mode
2010 Silverado 1500 w/6 speed. How does tow/haul mode effect a Diablo ecu/tcm tune? Does the Diablo tune also change parameters in tow/haul?
Re: tow/haul mode
tow/haul works the same as it always did, tune changes still apply, so more power no matter which mode.
trucks2361
Re: tow/haul mode
thx for the reply. what about the diablo trans tune? The standard diablo tune changes shift points and shift TQ correct? doesn't the tow/haul also do this with the factory settings? so does the tow/haul alter the diablo shift points and other options?
Re: tow/haul mode
No, shift points are not changed.... the preset canned TCM tune changes shift pressure/firmness, and shift quickness (how quick it performs the actual shift)...
You'd still use the tow/haul button like you normally would. That tells the transmission to use different shifting settings for towing (higher shift points), same as stock tune does...
