The car does not see the update
Alex999mu
Post by Alex999mu »
Hello, I'm asking for help. I connect the device to the car and get this message, I click the checkbox and receive the following message. I go and connect the device to the PC, it says that it is updated. I go to the car and the same thing happens, what should I do? I am attaching the info.xml file.
info.xml
(2.42 KiB) Downloaded 141 times
Re: The car does not see the update
this is a pretty old device, post the info.xml file from the intune drive and we'll take a look.
Alex999mu
Post by Alex999mu »
Thanks for your answer, I have attached the file.
info.xml
(2.3 KiB) Downloaded 148 times
Alex999mu
Post by Alex999mu »
Did you manage to watch it?
palich85
Post by palich85 »
I've the same problem. Can you help me? My info file
info.xml
(2.75 KiB) Downloaded 67 times
palich85 wrote: Wed Jun 11, 2025 4:43 am I've the same problem. Can you help me? My info file
this device is not asking for an update?
palich85
Post by palich85 »
Just these messages.
I downloaded the latest updates 04i and 01u from the forum, but they don't help. Is there a solution?
the infof ile you posted is not asking for an update, which i would expect based on the images provided. Post a new copy of the info file please.
palich85
Post by palich85 »
This is the last one.
info (1).xml
(2.83 KiB) Downloaded 79 times
its asking for it now. Update with the update agent software and it should download the file.
palich85
Post by palich85 »
Hi!
The update agent that is located on the dcx memory card is not working. Writes that there is no connection to the server. You can send the update files to [email protected] ? I will manually update the device myself.
you need to use the update agent software from our website and install it on your PC.
The old intune updater that lives on the device is no longer supported.
