your vehicle is not in our database cal_id is RYAF2TZ
Hi there
I have mustang gt 2002 m, my new diablo predator U7146 not working with my car as its shown mesg
your vehicle is not in our database. contact your dealer for a free update cal_id is RYAF2TZ
Please i need your help i am from United Arab Emirates (Dubai)
RE: your vehicle is not in our database cal_id is RYAF2TZ
Can you please tell me what revision is on your Predator now?
thanks for your reply
Its new device, sorry bro what do you mean by revision and from where can i get it?
Top line of the main menu when the tool is powered up.
Predator V.9r05
I have a feeling that this is an odd export calibration as we have no record of that calibration from Ford.
So what can i do i like your device any suggestions
do i need to change the device or should i change the car ECU if so which one will be ok with your device.
The only suggestion I can come up with would be to see if you can get a dealer to update the PCM to see if it will change the calibration to one that we currently support.
i dont think the dealer here will do such things
i'm having the same problem as you are i just bought mine yesterday what do we need to do???
Guys, hang on to your Predators. I have the tunes made for these calids but they need to be added to the tool. We'll be making a revision very shortly, I am just trying to fix a Mach 1 rev limiter as well...
Kevin@Diablo
Kevin@Diablo
Oh nice words bro any update Mr Kevin
Waiting...........
Waiting...........
I got the updat file and it works with my car
a big thanks for Mr.Kevin for his support he is very helpful
Kev is the man!
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
