Turbo whine
Posted: Wed Nov 19, 2008 7:06 am
by jackpot44
I am using 7165 with the 9r05 installed on a 05 Ford 6.0. 4" exhaust, AEF air system. I get a loud whine in the 100hp mode at most all RPM. I have read on the blog that some turbo shafts or bearing go bad, can anyone tell me what is going on? Thanks
RE: Turbo whine
Posted: Wed Nov 19, 2008 9:24 am
by sohfast94
It's just because it's a VNT turbo and when you put the intake on it there no longer a resonator so you're naturally going to hear it more esecially with the added duty cycle of the 100hp tune for the VNT.
RE: Turbo whine
Posted: Fri Nov 21, 2008 10:10 am
by jackpot44
Thanks a lot, makes sense. Is there any thing I can do to quite it down? I don't remember the noise with older tunes.
RE: Turbo whine
Posted: Fri Nov 21, 2008 10:14 am
by sohfast94
Why you don't like it? I guess if you wanted you could use a K&N Filter sock. That might help...
RE: Turbo whine
Posted: Fri Nov 21, 2008 10:20 am
by jackpot44
Its not me.... its the Madame. Somethmes one must compromise.
RE: Turbo whine
Posted: Fri Nov 21, 2008 11:16 am
by sohfast94
Ahhh now I see. Yeah try the K7N sock that should quite it down some... Does the intake box have a cover?
crom vs. frg file
Posted: Fri Nov 21, 2008 11:16 pm
by salty110
Im having trouble getting updates for the surging issues with the new program(R05). I downloaded the file from the sticky but cannot open it. I checked the old downloads and they are CROM files and the new ones are FRG. what is the difference?
2003 f-350
u7165
r05
vxap2
RE: crom vs. frg file
Posted: Sun Nov 23, 2008 6:31 am
by jackpot44
Yes it has a cover. (sorry for the late reply, had to go to work)
Re: crom vs. frg file
Posted: Mon Nov 24, 2008 10:03 am
by sohfast94
salty110 wrote:Im having trouble getting updates for the surging issues with the new program(R05). I downloaded the file from the sticky but cannot open it. I checked the old downloads and they are CROM files and the new ones are FRG. what is the difference?
2003 f-350
u7165
r05
vxap2
Could you post a link of htis file you're tyring to download?
RE: Re: crom vs. frg file
Posted: Mon Nov 24, 2008 11:16 am
by salty110
sohfast94,
My computer skill are seriously limited, I copied this from the very first page in the ford diesel forum, they are listed as a sticky
thanks.
Here are the 60hp and 100hp files. If your calid is not posted please post it up. These fix any low injector pressure codes as well as any surging your having at WOT. They have been tested and approved. Any Feedback is welcome.
vxap2n2_60hp.frg
Description:
Download
Filename: vxap2n2_60hp.frg
Filesize: 153.69 KB
Downloaded: 6 Time(s)
vxap1n6_60hp.frg
Description:
Download
Filename: vxap1n6_60hp.frg
Filesize: 153.61 KB
Downloaded: 3 Time(s)
vxap1n6_100hp3.frg
Description:
Download
Filename: vxap1n6_100hp3.frg
Filesize: 152.95 KB
Downloaded: 17 Time(s)
vxap2n2_100hp3.frg
Description:
Download
Filename: vxap2n2_100hp3.frg
Filesize: 152.97 KB
Downloaded: 14 Time(s)
Posted: Mon Nov 24, 2008 11:57 am
by sohfast94
Here you go.
Posted: Mon Nov 24, 2008 2:48 pm
by salty110
OK,
I think I have both the 60 and 100 hp tunes downloaded on my computer. Now how do I install it to the predator.
Thanks for the help
