MAFia and Paxton
MAF.i.a Support
Berik
MAFia and Paxton
Post by Berik »
I've installed PAxton Novi 1200 for my stang gt
Also I bought MAfia.
Do I need custom tuning?
Can I programm with Predator vr7140?
RE: MAFia and Paxton
If it came with the VR7140, you can simply load the tune from the Predator and go.
Berik
Post by Berik »
I've istalled Mafia and set to position 2. After that engine does not go upper than 4000 rpm. Did I do something wrong?
kmac1
Post by kmac1 »
If you installed the proper tune for mafia setting 2 it should run fine... If not maybe you have a mechanical issue. Does the MAF sensor have the filter clamped directly to it or do you have the u-bend between the maf and filter? The correct way is to have the filter clamped directly to the aluminum maf sensor housing.
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
Return to “MAF.i.a”
