Throttle Boost
Posted: Mon Oct 21, 2024 1:35 pm
by JimMc
All,
Is there some sort of how-to/walk-through on how to adjust throttle boost? I'd like to adjust this on my Challenger but haven't been able to figure out how to do it with the Trinity. I currently have a tune from AJ at Hemituner Performance that was done after I put a supercharger on my R/T. My goal is to get rid of the throttle lag much as how the Pedal Commander does. Someone told me this can be done via the Trinity. Any help would be appreciated!
Thx...
Jim
Re: Throttle Boost
Posted: Thu Oct 24, 2024 4:16 pm
simply increase the value in the throttle boost param by maybe 10% to start, then load the tune with that change and see how you like it. if you want more, you can go in and add more to your liking.
Re: Throttle Boost
Posted: Fri Oct 25, 2024 3:09 pm
by JimMc
mikel wrote: Thu Oct 24, 2024 4:16 pm simply increase the value in the throttle boost param by maybe 10% to start, then load the tune with that change and see how you like it. if you want more, you can go in and add more to your liking.
I guess my first issue is figuring out how to make changes to the tune. Is that done from the tuner itself or do I need to connect the tuner to my laptop and use software (which program) to write it to the tuner and then resend it to the vehicle?
Re: Throttle Boost
Posted: Wed Oct 30, 2024 11:31 am
connect to the vehicle., pick the tune then make the adjustments you want, then load the tune to the pcm.
Re: Throttle Boost
Posted: Wed Oct 30, 2024 5:59 pm
by JimMc
mikel wrote: Wed Oct 30, 2024 11:31 am connect to the vehicle., pick the tune then make the adjustments you want, then load the tune to the pcm.
Ok, thx. I didn't know if I had to load the stock tune, make the changes to the custom tune and then resend it back to the vehicle.
