on my 5.7 300c it makes hp up to 5500
Posted: Sun Nov 23, 2008 1:37 pm
by venom_srt8
but with shift increase it doesnt shift hard but if i go to 6000 it shifts hard .but if horsepower drops on the dyno at 5500 wont the 6,000 be to high and loose power i have dyno sheets on my car and it made its power
at 5500 then fell hard after im running 9r08 any help thanks
RE: on my 5.7 300c it makes hp up to 5500
Posted: Sun Nov 23, 2008 2:04 pm
by Quick
You got it. The 5.7s have the best performance at the stock shift points. The raised shift points feel and sound cooler but you won't get down the track as fast.
Posted: Mon Nov 24, 2008 3:32 am
by smoke74
everyone says 6000 rpm shiftpoints work better and claim improvements at the track, i agree the hp quickly falls down after the peak hp was reached on these cars. also shift firmness should work regardless of the shiftpoints at least thats how i recall it on my car.
venom all i can suggest is to try the different settings for yorself. remember the point is to get the revs on the next shif back where the power is made.
Posted: Mon Nov 24, 2008 4:29 am
by Quick
I don't know much about it but, like you said above, you have to also consider where you land on the rpm curve when you hit the next gear. So you have to balance both ends right? If you're too low at the bottom of the next gear you're going to lose time but if you run off the power curve on the top end you're going to lose time. How did where you fall after the shift look on the dyno?
Re: RE: on my 5.7 300c it makes hp up to 5500
Posted: Thu Nov 27, 2008 2:19 pm
by venom_srt8
Quick wrote:I don't know much about it but, like you said above, you have to also consider where you land on the rpm curve when you hit the next gear. So you have to balance both ends right? If you're too low at the bottom of the next gear you're going to lose time but if you run off the power curve on the top end you're going to lose time. How did where you fall after the shift look on the dyno?
heres my dyno report should i go stock shift or 6,000 thanks
RE: Re: RE: on my 5.7 300c it makes hp up to 5500
Posted: Thu Nov 27, 2008 3:02 pm
by Quick
From the graph it kind of looks like stock would work best? What RPMs do you land at right after the 1-2 and 2-3 shifts? Wouldn't anything about 3750 or above be ideal? Johan recommends stock. Stock is what guys have recommended after carefully comparing their track times.
Personally, I'd go 6,000. You're driving it every day. More RPM and noise just sounds cooler and feels better. I spent about $1,500 on an exhaust which probably bought me 10 to 15 hp. But it puts a big smile on my face every time I drive the car.
Posted: Thu Nov 27, 2008 11:12 pm
by UARPerformance
Stock shift points will get you best et"s. Manifold is dead at 5600 with cams & heads. Strokers will use it further. long intake runners make great torque but sacrifice up top. 4000lbs need torque to move & torque drops earlier
Posted: Fri Nov 28, 2008 12:55 am
by ZMagnum
I'm manually shifting mine and trying for 5800 rpms. At the track shifting slightly higher yielded a faster trap speed by slower ET.
Posted: Fri Nov 28, 2008 1:07 am
by UARPerformance
My car runs 7.70s in 1/8 on 125 shot at 5600. Any higher & it goes slower ET's. Thats on regular BFG KDW's 40 PSI High 1.70s sixty footers
Posted: Fri Nov 28, 2008 1:16 am
by Mike_Levy
Now how the hell do you get 1.70 60' times? I can't get better then 1.90 and I have AWD. And with that 1.90 comes a lousy 7.99 1/8th at just 90mph.
Gotta be the added weight of the GC over the Charger just not wanting to move.
