what are these parameters??
Posted: Wed Nov 26, 2008 10:37 am
by 87gtNOS
Hey guys...please tell me what these do.
Downshift MPH
Shift Time
Upshift MPH
Upshift MPH vs TPS
Upshift RPM
RE: what are these parameters??
Posted: Wed Nov 26, 2008 10:49 am
Downshift MPH: MPH at which it will allow a downshift to happen
Shift Time: How long it takes to make a WOT shift
Upshift MPH: Minimum MPH required for said upshift.
Upshift MPH vs TPS: Control of part throttle upshift points vs. Throttle position.
Upshift RPM: RPM at which a WOT upshift will be commanded.
Re: RE: what are these parameters??
Posted: Wed Nov 26, 2008 2:37 pm
by 87gtNOS
mikel wrote:Downshift MPH: MPH at which it will allow a downshift to happen
Thanks Mike.
Can you expand on these answers....
For what Throttle position does the Downshift MPH affect? If I raise it, what happens?
Upshift MPH- so I can raise this and it won't shift until I reach a certain mph? But other variables affect it? Like TPS?
I understand the others! Thanks
RE: Re: RE: what are these parameters??
Posted: Thu Dec 11, 2008 8:49 pm
by 87gtNOS
ttt
Posted: Tue Dec 16, 2008 7:45 pm
by 87gtNOS
ttt
Posted: Tue Dec 16, 2008 10:09 pm
by 06MonteSS
I believe Mike's out on vacation for a bit...
Posted: Tue Dec 16, 2008 10:27 pm
by 87gtNOS
Right on!! I'll wait!!!
Posted: Wed Dec 17, 2008 11:13 am
Honestly, best explaination I can give is to make small changes to these params one at a time so you can 'see' what they do for yourself.
Basically they change the relationship of when the PCM will command an upshift or downshift.
Downshift MPH is the minimum MPH you must be traveling to get it to downshift.
Re: RE: Re: RE: what are these parameters??
Posted: Wed Dec 17, 2008 4:09 pm
by 87gtNOS
mikel wrote: Downshift MPH is the minimum MPH you must be traveling to get it to downshift.
So if I want it to downshift sooner, I raise the mph? I want it to downshift easier as I 'tip-in' on the throttle.
