Page 1 of 3
Tune will not load in 05 Hemi Ram
Posted: Wed Nov 26, 2008 10:29 pm
by kenandjenn
I was able to update my tuner and install the TCM crom just fine. However, the tune will not load.
It keeps telling me to turn the key on/off (three time) and then says make sure key in on. I have the key on, but it says try again.
RE: Tune will not load in 05 Hemi Ram
Posted: Wed Nov 26, 2008 10:42 pm
by dodge4x4810
I have the same exact problem. I am glad to see that it is not only me.
Posted: Wed Nov 26, 2008 10:48 pm
by kenandjenn
I'm gonna try to drive it after it fails to load. Someone else got it to work doing that.
Posted: Wed Nov 26, 2008 10:58 pm
For some reason it is not seeing your key cycles.
Try pausing for a few seconds between cycling on/off and pressing OK.
Posted: Wed Nov 26, 2008 11:58 pm
by kenandjenn
I tried that and it did not work. It will write to the PCM, but now fails after that. It says that one part of the tune fails.
I have returned the truck back to stock and will await further advice.
Posted: Thu Nov 27, 2008 2:51 am
by ~RAM~
It did it for me an told me to unplug the pred an I rebooted an went to the tune an installed again an everything went fine.
Posted: Thu Nov 27, 2008 5:13 pm
by gomango
OK, I have tried several times to load any tune to my truck and nothing was on except for the ignition, it simply will not load any tune to my truck or complete. The last time I tried it took me four times to load the stock program to the truck thank god it finally aloud me to do that. I'm not sure whats up with this tuner but I loaded SuperChips back in with 87 tune and work fine and ran like a charm. I will not be trying this again anytime soon, I'm afraid at some point it will not reload my stock program and then I will be really screwed.
Posted: Fri Nov 28, 2008 5:19 pm
by BMRbrnSNRbrd
I've had the same problem with my '04 Ram Hemi. Every time I attempt to modify the tune (which frankly isn't much as we still can't change shift points) it gets all the way to the end where it asks for you to cycle the key. It asks three times and then aborts...very irritating.
Posted: Fri Nov 28, 2008 5:22 pm
by johan
We are aware of this issue and working on a fix for it.
Posted: Sat Nov 29, 2008 1:44 pm
by whitehemi
My Diablo says the same thing but it does it load if I go back and check. it also shows up on the truck. Although I would like to be able to complete the process via the Diablo's commands....
Posted: Wed Dec 03, 2008 12:04 pm
by chefred112
..same with me...looks like at the point wer alll having this issue is when the Tcm portion tries to load....
Posted: Wed Dec 03, 2008 12:08 pm
We are testing this in house right now, should have a fix soon.
Posted: Wed Dec 03, 2008 12:26 pm
by johan
Curious have you guys seen when you modify the params that all the params gets and asterisk ? Anyone ever see that?
Posted: Wed Dec 03, 2008 12:43 pm
by chefred112
..not here...just the params I modify will get an asterisk...
Posted: Wed Dec 03, 2008 7:13 pm
by BETHALHEMI
What he said.
