i3 for 2005 magnum 5.7 87 octane vs gas saver
Posted: Fri Jul 25, 2025 2:37 pm
by nickeh
on my 2005 r/t 5.7 magnum the tuner gives me the option of 87 octane or fuel saver. and when trying to install the discription is the same no matter which you pick? are they just the same program?
Re: i3 for 2005 magnum 5.7 87 octane vs gas saver
Posted: Fri Jul 25, 2025 4:16 pm
can you post the device serial number here?
Posted: Fri Jul 25, 2025 11:45 pm
by nickeh
mikel wrote: Fri Jul 25, 2025 4:16 pm can you post the device serial number here?
small white sticker on the back top line x00011310 bottom line 201677642
Posted: Mon Jul 28, 2025 3:26 pm
so we've confirmed no 87 tune here, are you seeing this in the advanced tune list, or in the easy tune menu?
Advanced will show the actual list of available tunes.
If it is showing there, can you share a pic please?
Posted: Mon Jul 28, 2025 5:15 pm
by nickeh
mikel wrote: Mon Jul 28, 2025 3:26 pm so we've confirmed no 87 tune here, are you seeing this in the advanced tune list, or in the easy tune menu?
It is in the easy tune menu not in the advanced.
Posted: Tue Jul 29, 2025 10:13 am
ok, if you select that option in ez tune it will likely select the MPG tune, but id suggest using advanced.
