i have a 2006 silverado 5.3 1500. when i change my axle ratio and tire size my abs and brake light come on. if i install the stock tune its fine? is there an update> i have a U7192 software Rev:2.00 hardware Rev:1.01. i couldnt find any downloadable updates online. any ideas?
thanks
Danny
06 silverado 1500 5.3 abs and brake light on.
dcashley84
RE: 06 silverado 1500 5.3 abs and brake light on.
Try dialing in the tire size up or down in half inch increments. The new ABS modules in these trucks are very sensitive to the correct tire size being input. Once you get the correct size dialed in, the lights should go out.
There have been several updates to that tool but none to address any issues with the tire size parameter.
dcashley84
Use the aspect ratio (70) to fine tune. Try setting it to 72, 75 or 68, or 66 to see if that helps.
