Page 1 of 2
2008 Ram - Predator does not support?
Posted: Sat Nov 29, 2008 4:33 am
by Ramhemi03
I have tried several times to hook this up to my truck and i get Predator U7137 does not support
Calid:05094507AH
Tool update might be availeable.
The tool says that I dont need an update??
I got this from the tool
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM8 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '151041241'.
Part number = 'u7137'.
CROM version = 'u7137-9r01 11/11/2008 04:29:51 PM boot3'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Origional backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool SUPPORTS multiple ECUs.
Config does NOT indicate multiple ECUs.
Tool reports 1 ECUs.
RE: 2008 Ram - Predator does not support?
Posted: Sat Nov 29, 2008 9:27 am
by Ramhemi03
Serial:900b4d9
Part:u7137 u7137
Version:v.9r01
Hardware:UNIV_REV2
Bus:SCI CAN
Born:11/11/2008 7414
Bus test PASSED
No tab or button have emerged when hooked up to my computer saying either calibration update or updater.
Posted: Sat Nov 29, 2008 3:17 pm
by Speed1B
You need to download the revision. 9ro2.
I have an 08 and no problems.
Posted: Sat Nov 29, 2008 9:49 pm
I seem to recall this to be a fairly new calibration for the 08 Rams.
Hopefully we can get the file from Dodges website and get it supported first thing next week.
Posted: Sat Nov 29, 2008 10:29 pm
by Ramhemi03
Truck is brand new got it last month and as for revision 9ro2, I can't seem to find it on the downloads page
Posted: Sun Nov 30, 2008 12:42 am
by 07HemiR6
Ramhemi03 wrote:Truck is brand new got it last month and as for revision 9ro2, I can't seem to find it on the downloads page
Its here: http://www.diablosport.com/index.php?na ... 0086735f8b
Posted: Mon Dec 01, 2008 9:50 am
by 00pumpkin
Mine is saying the same thing. I have the updated version in it and a re-calibration tab did not pop up in the DS downloader so I assume that it thinks I dont need one. Is there a fix for this? Did it not get tested on 08's??
Posted: Mon Dec 01, 2008 10:01 am
by johan
There is a new update for the 08's and 04's that came out recently, we are working on adding them in, should get added in this week.
Posted: Mon Dec 01, 2008 10:37 am
by Ramhemi03
Would an aftermarket remote starter cause this issue also??
Posted: Mon Dec 01, 2008 11:11 am
by johan
Ramhemi03 wrote:Would an aftermarket remote starter cause this issue also??
It does cause issues yes, but not the one you are seeing, you have a new pcm update from dodge that we do not support yet as it is very new.
Posted: Mon Dec 01, 2008 11:17 am
by ~RAM~
What would remote start mess with?
The wife is gettin me one for christmas. Should I tell her nevermind?
Posted: Mon Dec 01, 2008 11:45 am
by 00pumpkin
I have a factory remote start and still get the same message..........
I just bought my truck back in September. I guess it must have the newest update.
Posted: Mon Dec 01, 2008 12:01 pm
by johan
Remote starts (some) mess with the key on/off settings, but most people who have them and predator just disable it while programming.
Posted: Mon Dec 01, 2008 2:18 pm
by Quick
Especially aftermarket car alarms, and I guess remote starters, can/will effect tuning the car. If there's problems it seems to happen when you try to download a tune or changes to the car. So it hangs or fails to download a tune/change. I've never heard of anything getting screwed up but it just doesn't do the download to the car. A calid problem is different and means that the predator is talking to the PCM just fine but it's detected a "version mismatch" between the PCM image and the Predator version.
I have to disconnect (pull the fuse) on my aftermarket car alarm to tune my car. I can hook up the predator and do logging just fine but if I want to download a tune or quick adjust changes I have to disconnect my car alarm first.
Posted: Mon Dec 01, 2008 10:24 pm
by Speed1B
I have an 08 and everything works great. I downloaded the rev 02 before i even used it.
Unbelievible how good my truck runs now. Night and day difference and gas mileage didnt change.
Are there any tweaks coming soon Diablo staff? I mean are we taking baby steps into this here or do we have the best we are gonna get?
