ORIGINAL ECM/ECU FAILS WITH DIABLOTUNE INSIDE MARRIED TO MY I3
miltonvaldes
Post by miltonvaldes »
I have a Chrysler 300 3.5 2006 married to my I3 tuner,
the ECM/ECU fails with the i3 tune married inside,
the repair shop said it can not be repaired so, i bought another and they program the VIN number and Part to a new ECM/ECU.
What can i Do now to rescue the tune married on the old ECM, it doesnt matter that the new ECM has the same VIN Number the I3 Tuner says: "the vehicle is currently not supported; an update may be requiered;"
I did conect my I3 to my PC and it download again the vin number calibration for Chrysler 300, but back in the car it does not recognize and says the same messeage
WHAT CAN I DO TO HAVE THE I3 BACK AGAIN IN THE NEW ECU?
The new ECM works well like Stock
UPDATE:::::: my original faulty ECM married to the i3, works after applying heat, but when i connect to the obd2 to proceed Unmarried it, i couldnt do it, the messeage says the same as on the attached picture, i think the i3 got confused because when the new stock replacement ECM with the same Vin number and part number, update on PC and then same displays as in the picture, and today when the faulty computer works, i update on PC the i3 after conecting to the obd2 and update again the vin number calibration, but the same display as the picture.
i think the i3 got confunse with 2 ECM and the same vin number,
I WANT TO UNMARRY FROM THE FAULTY ecm AND MARRY TO THE NEW COMPUTER
I NEED HELP SO THE I3 DETECT THE CAR WITH THE MARRIED COMPUTER (NOW WORKING) TO CONTINUE TO UNMARRY IT
please help
thanks MILTON
Re: ORIGINAL ECM/ECU FAILS WITH DIABLOTUNE INSIDE MARRIED TO MY I3
give us a call so we can reset it, 561-908-0040
miltonvaldes
Thanks,
i Called to tech services on the phone and explain the problem,
they ask me for the i3 serial number, wait a little
and told me to connect to my PC and update the i3 with ignition agent then go to the car with the new ECM same vin number
and at first it does not recognize and the i3 ask me for a update calibration vin number and restart i3 and the it began to write original backup, and everything fine, thanks for your help.
milton
