2020 Grand Cherokee Hemi. I’ve tuned the car twice and restored to stock. No where are the options for disabling MDS, Fan controls, rev limiter, etc…
I’ve tried standard and advanced. Used the 91, 93 and Diablosport tunes. After reading the stock tune the only options that show up under Modify Parameters are tire size and disable speed limiter.
What am I missing? Are the advertised options not available on 2020 and newer?
Can not disable MDS and other options?
Re: Can not disable MDS and other options?
Certainly sounds like they are missing. Can you post the info.xml file from the i3 drive or the devices serial number please?
jnmarshall
Device numbers
X00011310
202311342
Currently back to stock.
Info.xml
X00011310
202311342
Info.xml
Code: Select all
<tool_info platform='CHIMERA'>
<registration sn='202311342' status='0' tool_oem='DIABLO' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='3r06d'/>
<application name='updater' rev='2r02b'/>
<application name='gui' rev='2r02q'/>
<application name='installer' rev='2r02m'/>
<application name='logger' rev='2r01u'/>
</applications>
<databases dbnames='2r01f' dtc='2r01a' vin='2r01r' SAE='3t01xe' gui='2r00n'>
<database mfr='DCX' tune='2t03gd' pid='2t01vg'/>
<database mfr='FORD' tune='2t03gz' pid='2t01tc'/>
<database mfr='GM' tune='2t04hs' pid='2r01t'/>
</databases>
<system rev='1r01c' config='3r01d'>
<kernel release='4.11.12-rt16-chimera8' version='#3 PREEMPT RT Wed Apr 12 15:42:11 EDT 2023'/>
<option name='Wifi' enabled='false'/>
</system>
<last-connected vin='1C4RJFLT3LC235542' mfr='DCX' ecus='2' factory_data='yes'>
<ecu calid='68449435AE'/>
<ecu calid='68449258AC'/>
</last-connected>
<licenses available='1' tuned='0'>
<option mfr='DCX'/>
<option mfr='FORD'/>
<option mfr='GM'/>
<option config='CustomTuning'/>
<option config='FuelDiesel'/>
<option config='FuelGas'/>
</licenses>
<reg reg='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'/>
</tool_info>
OK, I passed this over to our support department, they should contact you at your email address on file.
Sounds like its all good? Enjoy!
jnmarshall
Rick got it setup for me. Apparently I was going into the modify menu option too soon and needed wait till the tune is ready to be flashed.
good deal!
Have a 2010 Ram 1500 5.7 and I have the i3 sport and installed the tow tune and turned MDS off and I have also did a full delete for the MDS but then I go back to look and it’s automatically turned back on. What is the problem or how do I fix this?
I have updated the tool and reverted back to original and did it again to just see if it was a glitch but same result. Please help!!!
thats just how the parameter displays, it always defaults to ON, that doe snot mean thats how its set in the PCM.
