Wrangler jk p0733 after tuning
Aleex
Post by Aleex »
Hi,
I have a Diablo T2 EX with modified PCM on my wrangler jk rubicon 2014. After tuning and modifying parameters, I get an issue with the gear; it halt at 3rd gear with error code p0733, no shifting.
I reset the tuning to factory with no changes, still halt at 3rd gear.
Re: Wrangler jk p0733 after tuning
does the jeep have aftermarket gears installed?
thats usually what causes this, and the correct ratio needs to be programmed to correct it.
Or did you just install it and set the gear ratio for the stock gears?
if so restoring should resolve it, and you do not need to program for stock gears, it already knows what they are.
