I have an 2005 SRT-4 with a Stage 2 w/o Toys upgrade, Mopar CAI, and Mopar exhaust. That's it. Everything is hooked up as stock and/or recommended. Running California 91 Oct gas.
Got my Predator last night and of course within 30 minutes of opening I had to install the supplied 93 Oct tune.
The unit came with Rev. 9R09 but since I don't have the USB kit yet (on order) I couldn't update it. Decided to proceed anyways to see what would happen.
I'm not tuning expert mind you. This was absolutely a simple process. The unit walks you through the steps explicitly. It tells you when to have the ignition on and off and holds your hand the whole way. Very cool!
Drove the car to work today which is comprised of 10 miles of city, 30 miles of highway, and 5 miles of curvy mountainous roads. In the city, you wouldn't know anything has changed (which concerned me at first...). Ditto on the highway at first. Then I stomped on it at 70 mph in fifth gear. Car took off as normal and boost built up on gauge to twenty and held and held and held. Next thing I knew I was well above the legal speed. I quickly slowed down with a smile of my face.
Typically my Stage 2 will spike to 19 lbs of boost and then generally drop and hold to 15 or 16 psi. Those numbers are only valid on colder days as the density of the air has a real effect (warmer equates to less boost pressure.)
Today was cool but not cold enough for those numbers normally. The ability to hold 19 and 20 lbs of boost are most definite attributed to the Predator. Very cool indeed.
Possibly dangerous too. Without a wideband, I don't know if I'm running lean or not at those numbers. So with the new tune I really have to watch that I don't over boot until I can confirm that I'm at a safe level. BTW, I could easily now boost right past 20 PSI (right off the gauge) if I wanted to. I won't and don't recommend that anyone does. But it is evidence that this little unit has reprogrammed the ECU.
Question. I believe I can buy canned tunes that more closely reflect my modification situation. Assuming that's true, whom can I go to and is there anyone on this board that can help me out with that? Let me know how much you would charge and what you need from me.
Back to the unit. So far I'm very pleased and can't wait to play with it some more.
Thank you guys at Diablosports!
Best Regards,
Landmizzle
