2014 Ram 1500 5.7 electric fan conv
A10lodr
Post by A10lodr »
I have done the electric fan conversion for the Ram 1500. I'm putting in a 180 degree t-stat. How do you set the lower temp to turn the fan off after the motor gets to x degrees, it currently does it around 203 degrees? I know how to set the fan turn on temp, just not the new turn off temp.
A10lodr
Re: 2014 Ram 1500 5.7 electric fan conv
Post by A10lodr »
Update, talked to Diablosport and the only way to change the lower bound for electric fan turn off temp is a custom tune.
theres no way for the i3 to know you have added an e-fan, hence any adjustments need to be made in a custom tune.
If you need a change made, post the last tune written from the device.
