Cannot clear out memory
99GT-owner
I keep getting an "out of memory" error when I try to data log. I have tried the live table reset, and nothing. I just updated to 9R05. I had perfect control on 7r50 but now that I updated it, i cannot data log or delete memory.
Any help?
Any help?
RE: Cannot clear out memory
Hmmm...I thought this was fixed on 9r05, let me look into it.
99GT-owner
Me too, I checked out some other posts and it seemed to be a r03 problem.
is it when you try to log in a certain section? Do you have a custom tune loaded?
Kevin@Diablo
Kevin@Diablo
99GT-owner
No, I don't have a custom tune. I just go to data log and it says out of memory. There is no way to delete it too...
Ok, I need just a bit more info. When you click "Diagnostics" then "Realtime Data", is this when the out of memory message comes up? OR do you hit "all" once you are in the Reatime Data menu and then get the out of memory message? I am trying to duplicate this so I can fix it but it only comes up when I hit "all"
Thanks,
Kevin@Diablo
Thanks,
Kevin@Diablo
99GT-owner
AH, yes. I was misunderstanding you. The menu comes up and it is when I hit "all" I get the error.
99GT-owner
Any info yet? I have found I am able to live stream to CMR DAT and save log files to view in Dataviewer. But their is no space on the programmer to data log...
Try logging in the other menus. All the parameters are available in them, as far as I know the all menu is the only one with issue...
Kevin@Diablo
Kevin@Diablo
99GT-owner
You are correct Kevin, it only does it after I select "All". Any Idea why?
We'll probably just have to remove the ALL menu and make sure all the pids are available through the rest of the sub headings...
Kevin@Diablo
Kevin@Diablo
99GT-owner
I am in no direct need of it right now, I can always just data log through the CMR DAT until then.
