Clear instructions for Extreme puck
Posted: Tue Dec 09, 2008 2:36 pm
by Blacksmoke
Could somebody tell me who formated the installation manuel for the extreme power puck? It's impossible to see anything on the pics. I would need "clear" instructions for a 2006 C7 and a 1999 3126. Thanks.
Posted: Wed Dec 17, 2008 3:19 pm
by Blacksmoke
Is it possible to get those instructions or not? :shock:
Posted: Wed Dec 17, 2008 4:03 pm
Let me look into this for you...
Posted: Tue Jan 06, 2009 10:12 am
by Blacksmoke
It's been 27 days now and I'm still waiting. :(
Posted: Wed Jan 14, 2009 10:59 am
by Blacksmoke
Time flys when you're having fun.... It's even worst when you're not! One more week...
Posted: Wed Jan 14, 2009 1:34 pm
by puck_tech
Here is a clear picture of the 99 3126. I have circled the two connections that you will be pugging into in the diagram. You will need to make sure you connect the two connectors at the end of our harness to the ICP connector and the two connectors in the middle of our harness to the MAP connector. Please make sure to plug in both your male and female connectors to both the male and female connectors on our extreme puck harness.
The ICP connector will have white, green and brown wires going ito it and will be a three pin connector just like the one on our harness. The MAP connector will have pink, white and green wires going into it.
If this diagram does not resemble your engine please let me know.
On the 06 C7 I do not have a diagram available but do know that the sensors you are connecting to should have teh same wire colors as teh ones we show in our instructions. The MAP connector will be located toward the rear of the engine on the left side of the engine. It will be located beside the valve cover and will have a red tab you muct slide back in order to disconnect the connector from the sensor. The connector will have 3 wires going into the back of it and they will be pink, white, and green. Once you have it removed it will have a red cap in the connector just like the one on the extreme puck harness. Plug our harness into the sensor and the factory connector you just removed.
The ICP sensor is located toward the front of the engine on the same side of the engine and is going directly into the head. The connector will have a grey lock and will have three wires going into it. The wires shoud be brown, pink, and white. Remove it from the sensor and pug our Extreme Puck harness into the sensor and the factory connector you just removed.
Once all of this is done connect thExtreme Puck module to the wire harness, connect the switch to the harness and mount the module in the engine compartment.
If you have any other problems please let us know.
Puck_Tech[/url]
Posted: Wed Jan 14, 2009 1:44 pm
Thanks for sharing this Puck_Tech!
Posted: Wed Jan 14, 2009 4:40 pm
by Blacksmoke
Now that's what I call "CLEEEAAR". Thank you. I'm working on getting 06 up Caterpillar engine diagrams. I'LL post 'em when they come in. :lol:
Posted: Wed Jan 14, 2009 5:10 pm
Blacksmoke wrote:Now that's what I call "CLEEEAAR". Thank you. I'm working on getting 06 up Caterpillar engine diagrams. I'LL post 'em when they come in. :lol:
Sorry for the delay bud, let us know if you need anything else.
Posted: Thu Aug 13, 2009 2:39 am
by LJ137
I would like to see a diagram for the positions of the sensors on the 3126 engine. If someone could please help I would greatly appreciate it, Thanks.
Posted: Tue Aug 18, 2009 11:38 am
That diagram is for the 3126...
