2000 F250 tuning problem
gamemaster7600
Post by gamemaster7600 »
I have a 2000 7.3 PSD, its been tuned to the 85HP for a couple years and i want to tune to the 40HP tow and it will not take the tune...any ideas???
What is the best tune for towing a 4500lb trailer 600 miles,for power and mileage??
jbeasts10
RE: 2000 F250 tuning problem
Post by jbeasts10 »
What exactly is the programmer doing ,that it will not "take the tune"?Are you able to power the programmer up ?
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
Excursionist
Post by Excursionist »
I towed about 8000 lbs with the 60 hp tune with no problem. Do you have an EGT guage?
02 Excursion 7.3 liter
Monster Exhaust w/Power Elbow
Big Head Wastegate
High boost wheel
AFE stage 2 Intake
Updated U7170 v-9r03
Edge Juice w/Attitude
Cal ID TNAA7Y5
Transmission Transducer, Solenoid and Springs
gamemaster7600
Re: RE: 2000 F250 tuning problem
jbeasts10 wrote:What exactly is the programmer doing ,that it will not "take the tune"?Are you able to power the programmer up ?
It goes thru all the steps and when it tells me to turn the ignition to the on position without starting the engine, it says that the tune has failed....and yes..i am able to power the programmer up
Last edited by gamemaster7600 on Thu Dec 11, 2008 9:57 am, edited 1 time in total.
gamemaster7600
Excursionist wrote:I towed about 8000 lbs with the 60 hp tune with no problem. Do you have an EGT guage?
i do not have the EGT guage....i wanted to tune to the 60hp but it will not let me , i guess i will have to stay at 85 hp, until i get a reply from DS or a forum reply to help....
sohfast94
RE: Re: RE: 2000 F250 tuning problem
Post by sohfast94 »
What revision is this? when you power it up it will be in the top right...
Insert Clever comment here...
gamemaster7600
Re: RE: Re: RE: 2000 F250 tuning problem
sohfast94 wrote:What revision is this? when you power it up it will be in the top right...
v.7r19...just got off the phone with the tech....he wants me to send in the tool.....
