2001 f350 wont start after loading any performance tune
4rddan
Post by 4rddan »
I just got my U7170 programer and when I load any performance tune it activates a anti theft program and the truck wont start. I have to reinstall the factory settings. I called tech support and they tried to help by changing the anti theft option in the code but that didnt work either. I'm kind of waiting for a answer with a programer that wont work. It has the v.9r03 program in it. Any ideas?
Phil
RE: 2001 f350 wont start after loading any performance tune
Post by Phil »
The tuner is looking into this issue for you. Thanks
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
sohfast94
Post by sohfast94 »
You're the one with the VRAA7 calid right?
Insert Clever comment here...
4rddan
Post by 4rddan »
yes, VRAA7N7
sohfast94
Post by sohfast94 »
Have you tried loading revision 9r04?
4rddan
Post by 4rddan »
No, when I was on the phone they told me it wouldn't help me it was aimed at the newer 6.4 trucks
sohfast94
Post by sohfast94 »
Alright welll. I would try it just in case...
4rddan
Post by 4rddan »
OK, I loaded the v9R04 version. I downloaded the 85hp program in the truck and it wouldn't start. I changed it to the tow tune with the anti theft turned on and it didn't start then either. I put the factory tune back in and it starts. Another question, when I was first trying to get it to work I cleared the codes thinking that might help and when it didnt I cleared the KAM. Now it shows a code for that. Is that a problem or will it cause me problems? What is the KAM and what does it do?
sohfast94
Post by sohfast94 »
KAM = Keep Alive Memory... It clears every time you program or disconnect the batteries for any given amount of time. Do you ahve an excursion or something?
4rddan
Post by 4rddan »
2001 f-350 sd with mbrp 4" exhaust and afe stage 2 intake. When I bought the truck it was stock.
4rddan
Post by 4rddan »
So... You guys are still working on the not starting after tune downloaded problem. Right?
sohfast94
Post by sohfast94 »
Yeeeeessss....
sohfast94
Re: RE: 2001 f350 wont start after loading any performance t
Post by sohfast94 »
4rddan wrote:So... You guys are still working on the not starting after tune downloaded problem. Right?
Should be done and ready to test in just a bit.
sohfast94
Post by sohfast94 »
Try this and tell me what it does now.
u7170_ford_7_3-9t06a.crom
(1.75 MiB) Downloaded 104 times
4rddan
Post by 4rddan »
I downloaded the file and loaded it on the tool and now the tool says "the application is missing or corrupt" and wont do anything.I push continue and it restarts it and it says the same thing. It wont start at all and I cant connect to it with the computer either to try and reload the program.
