Engine braking EDIT: Added a different issue!
Discuss PredatorX based support, troubleshooting or general questions.
Moderators: garrett, mikel, sohfast94
Flatline392
Post by Flatline392 »
I love the Predator X and look forward to what’s to come with it. One thing I miss is the aggressive engine braking I had when all stock. I went back to the stock trans tune and actually like the shifts better with it. But still no engine braking, well like it used to be anyway. If there is ever an update to these stock tunes, some adjustments like adjusting decel fuel cutie something. But I am no tuner, and no clue what I am talking about, lol. Just know what I like by seat of pants feel.
Re: Engine braking
hmm, what vehicle here?
any other changes you made?
nothing we did should affect engine braking.
Flatline392
Re: Engine braking
Mike, I may have other issues going on as well other than engine braking. It has done this a couple of times. Under heavy acceleration the 2017 Challenger Scat, catches no traction at all revs to about 7k rpms and does not shift out of first or it’s going in to neutral (limp mode?) until revs fall back down and then proceeds to shift fine. It has the engine tune and the trans tune is stock. It has sport mode on and traction control is on. I am going to uninstall the engine and go back to stock and do moderate acceleration and see how it does, which it’s always been fine, so not sure that will repeat the run up to 7k in first gear issue. It’s only done it when I absolutely have no traction. The car only has about 9k miles. The tunes are the only mods done to it.
Re: Engine braking EDIT: Added a different issue!
not uncommon for the tcm limiter to cause limp more or have issues when you smack the internal TCM limiter at WOT.
Id suggest using the TCM tune.
Flatline392
I loaded the tcm tune back up and it instantly ran up to 7k catching no traction on a wot run and went into limp mode and then shifted out fine after dropping the rpms some. I am no longer in the beta test but I have noticed there have been several patches in testing, the notifications still come to my email.
If possible could I send a log or something to you guys and see if there is anything that can be done on y’all’s end? I am more than willing to pay for it. Or I would be willing to buy a different tuner from y’all and purchase a tune from you guys specific to my car? I know for one I need to quit hammering on it. I am running Continental ExtremeContact DWS06 Plus 275s on the rear. They did great the first 1k miles or so and they faded out quick. Thanks!
short of better tires, its likely gonna need a custom tcm tune to raise the tcm rev limiter a bit.
That said I wouldn't expect it to happen every time unless you are getting zero traction and it just zips right up to 7K RPM at WOT as soon as you hit the throttle.
Flatline392
It doesn’t do it every time. It’s all dependent upon of I can catch some kind of traction. Which with these Continentals, they are just not performing as well for me as they are for everyone else. What could I do to get a custom tune with you guys since I have the PredatorX?
Unfortunately PredatorX doe snot support custom tuning today.
We'd need to get you into an i3 or T2.
But honestly, 99% of people do not run into this, so I am not sure why its a regular occurrence for you unless the tires are just useless.
A pair of Nitto 555RIIs will make it feel like you picked up 50 rwhp :)
Flatline392
I wished I would kept my i3, I sold my Daytona and accidentally left it in the glove box, lol. It’s breaking traction like crazy. My wife would kill me if I already try to sneak another set of tires on already, lol.
Flatline392
mikel wrote: Thu May 14, 2026 4:24 pm Unfortunately PredatorX doe snot support custom tuning today.
This thing went completely bananas this weekend. It threw a few codes and all kinds of transmission issues. Codes were
P1D93 and code P1DC8. It has also has thrown codes, P0219 and UO402. I will also add, that I would run DTC after every install of Predator X can tune and would get U0100 just thought that was the nature of the beast. The transmission had too many gremlins to type down here and went into limp mode several times. So, I disconnected the battery for about an hour after uninstalling both the engine tune and the transmission tune. Made sure I had de-energized the car. I have put about 100 miles on it, gentle driving for the most part and some passing gear jaunts. The car is now shifting up and down fine again, no codes. Not sure what made the pcm,tcm, bcm so unhappy but that’s where we are for now, I did send in the data logs to you guys just in case you wanted to view. Billy
very odd, keep an eye on it.
Flatline392
Well, not the post I want to make. It started shifting from 3rd to 4th at 4k rpms regardless of the amount of throttle given. If you were in 1st and went past about 70% throttle it would go in limp mode. If you drove it gently it would still shift out fine. I took it to Apex Performance. They were supposedly going to clean up temp/pcm up and make sure no remnants or gremlins were hanging around. After holding my car about a week. I called for update and they said it wouldn’t shift from 1st to 2nd with out issues and it’s a valve body issue and it needs a rebuild. I asked them to send me the supporting evidence write up and we would go from there. They couldn’t give me squat. So I went next morning right as they opened the doors and picked my car up. How ever they drove it to “diagnose”, they infinitely made it worse. It would want to go into limp mode while driving home. Thankfully I did have the Predator X to clear the DTCs. But very odd thing, I had uninstalled both the tcm and pcm Diablo tune before taking to Apex. Once clearing the DTCs. It showed the PCM engine tune in place?? And the trans tunes didn’t show up as even available. So I continue on. The car went into limp mode again. Did the same thing cleared out DTCs and now the trans tunes showed up as installed??? Cleared it out and eased it the rest of the way home. I am going to attempt to take it to Dynomite Performance in Warrior as he seems to think it’s an issue in the tcm and pcm still. He is going to take it back to complete stock Chrysler form and go from there. Is there any possible chance you guys still have my PCM around? At some point last Thursday I sent y’all the data logs that were available. Billy
Not likely that we still have your pcm, but honestly, nothing in the pcm we sent will cause anything like this.
It does sound like a Valvebody issue from where I am sitting as well, and its not an uncommon failure. There are a few aftermarket upgraded versions available.
Return to “PredatorX for Dodge/Ram vehicles”
