What should I do when a file is too large to upload?
If you continue encountering upload failure issues due to the size limit of the file, begin by determining the maximum file size allowed in the website. Then, you may need to compress your file through the proper compression utility. In case of documents, it will be useful to delete unwanted images and pages from the document. In the case of pictures, reducing their resolution or format will make them significantly smaller. How do you make a file smaller to upload becomes an alternative solution.
