loss my trans module configuration
Start by say what I am working on. I have a 6.1 with nag1 transmission. I wanted to raise the idle a little because the motor has a small cam in it and I was having a surge issue. I had no issues with the truck prier. I plugged in my Diablo I3 and went into programming and raised the idle 150 rpm in park and drive. after it was all done. Started the truck and left it run till it went into close loop and everything seemed fine. So at that point I backed out of the barn. Everything seemed fine till I put it in drive. I felt the transmission engage into gear the truck started to move forward then stalled. I started the truck back up again and put in drive and the same thing happened. I got my scanner an hooked it up to see if there were any codes. I found code P1644 (incorrect configuration) Looking into this it appears somehow the tuner did something to my trans control module. I did not have any issues before. I try putting back the original tune and erasing the code but it did the same thing and the code came right back. I also notice that scanner was telling me that module no longer could see what gear the shifter was in. Any ideas on how I can get it configured back so it works? Or did I fry the module? I can't be the only one this has happened to. Needless to say I'm not very happy at this point.
