2003 cobra detonation
Posted: Tue Dec 23, 2008 2:01 am
by dtoirac
Hi the car is a 2003 cobra with a 2.80 pulley, kn fipk, off road x pipe, and flomaster catback. The car is detonating at wot every time i go from 2nd to third. I data logged it and the timing was around 20* so I took 5% with the predator (u7142) but still no luck. Oh this is on the 93 octane performance pulley tune.
RE: 2003 cobra detonation
Posted: Tue Dec 23, 2008 10:31 am
May want to try adding some fuel there.
Posted: Tue Dec 23, 2008 2:13 pm
by dtoirac
I added 2 % i dont know if to add more.
by dtoirac
I added 2 % i dont know if to add more. still no luck.
Posted: Tue Dec 23, 2008 3:09 pm
Try a larger change to see if it helps, like 10%
Posted: Sun Dec 28, 2008 2:10 pm
by dtoirac
tried that. still the same issue. timing is now at 16*
Posted: Fri Jan 02, 2009 8:05 am
by BrutalMetal
Check you fuel pressure at the rails to make sure your filter isn't clogged, what kind of miles are on the fillter?
If your retarding timing and adding that much fuel and it's still detonating it could be something your not considering..
