U7130 Extreme RKL 200hp & Perf Stacker tunes Downloads
Ok I figured it would be easier for you guys to download these custom tunes from HERE:
For pre 8r28 revision
05xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
12xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
15xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
20xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
25xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
Performance Stacker Tunes
05xxx http://www.diablosport.com/downloads/pr ... _stack.drd
12xxx http://www.diablosport.com/downloads/pr ... _stack.drd
15xxx http://www.diablosport.com/downloads/pr ... _stack.drd
20xxx http://www.diablosport.com/downloads/pr ... _stack.drd
25xxx http://www.diablosport.com/downloads/pr ... _stack.drd
Each one of these files contains 4 different Extreme RKL tunes:
Extreme RKL
Extreme RKL with less timing
Extreme RKL for stack
Extreme RKl for stack with less timing
For post 8r28 revision
05xxx http://www.diablosport.com/downloads/pr ... _toons.drd
12xxx http://www.diablosport.com/downloads/pr ... _toons.drd
15xxx http://www.diablosport.com/downloads/pr ... _toons.drd
20xxx http://www.diablosport.com/downloads/pr ... _toons.drd
25xxx http://www.diablosport.com/downloads/pr ... _toons.drd
The "ext_puff_toons" contain:
Extreme puff tune
Extreme RKL tune
Extreme RKL puff tune
Extreme RKL puff tune w/ no timing added
The "stack_puff_toons" contain:
Extreme RKL puff stack tune
Extreme RKL puff stack tune w/ no timing added
Performance stack tune
Where 05xx applies to any calid starting with 05, 12xx, 12 etc etc.
PLEASE NOTE: These tunes WILL deteriorate your stock transmission post haste.
Extreme RKL
Extreme puff tune
Extreme RKL tune
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
cameroneod
RE: U7130 Extreme RKL 200hp & Perf Stacker tunes Downloa
Quick question. I can load http://www.diablosport.com/downloads/pr ... _stack.drd into my predator, but it doesn't show up as four tunes, and when I try to load it, the truck acts like its back to stock. Any idea what I could be doing wrong?
- duallydave
the performance tune doesnt have 4 versions to choose from,only the extreme,i didnt notice much diference in the performance stack tune from stock either,its designed for the puck,probaly doesnt have any presure added.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
cameroneod
Ive got the puck.
- duallydave
03dodgeoffroad
modified03
cameroneod
Johan,
I'm Stacking with a TST, I can set the max timing the TST will add on top of my Predator. I'm running a 7130. I'm experimenting with the stacker tunes and settings on the TST, any info on timing would be great.
Thanks,
Lee
2005 CTD 3500 SLT 4x4 QCSB, Patriot Blue / Silver, aFe Stage2, MBRP Exhaust, HTT 62/13SS, Diablo Predator & TST Stacked, Isspro guages, Full DTT 48RE w/ Billet Flex, Input & Output
Thanks,
Lee
help please
how do i know which calid i have and do you have to return to stock setting b4 you download new programs
modified03
RE: help please
When you plug your programmer go to options i think and look for calid number and it will give you a number and thats it. Yeah i'm pretty sure you should go to your stock setting on your truck incase something messes up.
skunkedtis
Do these not work for the new r29 firmware, I finally got a chance to update the firmware and then I want to load the performance stacker toon. I have it the programmer it shows the one I dled but when I click it to install it says it wont work then goes to the next screen saying do I want to install it? Any help would be appreciated.
This is the one I am trying to load http://www.diablosport.com/downloads/pr ... _stack.drd Also what doe the 05 12 15 20 and 25 before the xxx mean?
Tyler
Tyler
- duallydave
- duallydave
skunkedtis
Thanks that helps a ton I am curious as to where I find out my calid number so I know which one I need to dl. I can get the toon in my programmer just not sure what one I need, I will play with it again tonight thank you for the help.duallydave wrote:is looks like u are trying to load the pre r29 tunes.u need the post ones.the ones that have puff in them.they work with the r29.u should be good to go.
Tyler
