predator u7145 having problems
dgs1
Post by dgs1 »
2008 mustang 4.0 can u run 93 octane gas on the 91 setting. when i install it the check engine light comes on. also i installed a bbk cai kit but the u7145 has no tune for bbk cai. which tune should i install
kmac1
RE: predator u7145 having problems
Post by kmac1 »
We don't have tunes in the Predator for the BBK cai. What codes does it have? You can check them in the diagnostics menu. Please post the full number and description...
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
dgs1
Post by dgs1 »
if there are no tunes for the bbk, should i retrun if for a different programmer or can i select one of the other cai tunes. The codes that appear are lean bank 1 and lean bank 2. Thanx alot for your support
bamachips
Re: RE: predator u7145 having problems
Post by bamachips »
dgs1 wrote:if there are no tunes for the bbk, should i retrun if for a different programmer or can i select one of the other cai tunes. The codes that appear are lean bank 1 and lean bank 2. Thanx alot for your support
You will require a custom tune for the BBK intake on your V6 even though they say it doesnt. I've just done one on the dyno and without a tune it was more then 30% off at WOT, a/f was in the high 16's.
Check out my website as I write tunes for these on a daily basis..www.Bamachips.com
Thanks, Doug.
Return to “Predator Ford Gas”
