stage 2.5 srt4 with DS?
Posted: Sun Dec 28, 2008 1:29 am
I just picked up a DS (It's en-route as I write this)
I have a quaife-equipped 03, with 04 injectors. No balance shafts, ported stock turbo housing, fuel pump rewire, stage 1 ecu and stage 2 wastegate.
What I'd like to do is put my old 03 ecu back in, leave the s2 wga installed, and push the turbo as much as possible. Because it's ported, I'm thinking I can push it more than a usual stocker (I'm thinking 22-23 psi).
A few questions-
1. Is the ported housing good for 22-23psi or does it not improve the efficiency of the stock center section
2. In order to get that high of boost (PCM controlled) do I need to get a 3-bar map sensor?
3. What about a tip sensor, would I also need to get a 3-bar tip as well?
4. Will the 04/05 injectors flow enough fuel for 23 psi, or will I need to go with the stage 2 injectors? The reason I ask is I heard that the true mopar stage 2 setup is way too rich...so much so that they use the same injectors in stage 3.
Sorry for all thew questions, but I think a lot of people are going to try to use the DS in this type of setup (eg emulating mopar stage 2)
A few questions-
