Page 1 of 2
91 and 93 gas can tune with U7134?
Posted: Fri Jan 02, 2009 2:06 pm
by Letxen3
how hard would it be to release the next revision with a can tune for the 91 octane gas users out west?
RE: 91 and 93 gas can tune with U7134?
Posted: Fri Jan 02, 2009 2:17 pm
These tunes were designed to be compatible with 91 octane since its simple to add timing if you have better octane available...
Posted: Fri Jan 02, 2009 3:26 pm
by turbofan
so it's OK to use the standard 93 oct. tune with 91 fuel?
Posted: Fri Jan 02, 2009 3:28 pm
They aren't listed as 93 octane tunes are they?
My understanding was that the Diablo tunes for the SRT4s were 91 octane minimum.
Posted: Fri Jan 02, 2009 3:57 pm
by Letxen3
your website promotes it as 91 and on the predator it says 93 i think let me go check. its just that everyone else is calling it 93 can tune.
Posted: Fri Jan 02, 2009 4:08 pm
by DMW
I just got my predator last week, and it says 93.
Posted: Fri Jan 02, 2009 4:16 pm
Interesting....we'll have to get Brian's input on this.
Posted: Fri Jan 02, 2009 4:41 pm
by Letxen3
i suggust that it should come with 2 can tunes one for 91 and one for 93.
Posted: Fri Jan 02, 2009 10:35 pm
by streetsteve
mine says 93 octane also would be nice if it was 91
Posted: Sat Jan 03, 2009 3:12 am
by turbofan
yes, the tune that comes on the predator is called the 93 octane performance tune.
Re: RE: 91 and 93 gas can tune with U7134?
Posted: Sat Jan 03, 2009 2:18 pm
by Letxen3
mikel wrote:These tunes were designed to be compatible with 91 octane since its simple to add timing if you have better octane available...
DMW showed me his log file and show about 6* of knock retard and he had put in 5.5% more fuel. are you saying he should add more timing also?
but still it should come with both tunes that way the average user who know lil about tuning can just plug and play and go.
RE: Re: RE: 91 and 93 gas can tune with U7134?
Posted: Sat Jan 03, 2009 11:09 pm
by 3chord
Yeah when I go into cali or az it would be nice to be able to flash it with 91.
Posted: Sat Jan 03, 2009 11:20 pm
by sfla_srt4
Letxen3 wrote:mikel wrote:These tunes were designed to be compatible with 91 octane since its simple to add timing if you have better octane available...
Adding timing will increase the knock..
Mike was saying the tunes were designed for the 91 because you could add more timing for the 93 octane.
Posted: Mon Jan 05, 2009 9:56 am
by sohfast94
sfla_srt4 wrote:Letxen3 wrote:mikel wrote:These tunes were designed to be compatible with 91 octane since its simple to add timing if you have better octane available...
Yup 91 minimum... Some 91's are better than others though depending on where oyu're located.
Posted: Mon Jan 05, 2009 1:39 pm
by turbofan
So just to 'malice sure, it's ok to run 91 in it? You mention that some 91 are better than others. Which would you recommend?
