Load % question
Posted: Tue Jan 06, 2009 2:53 pm
by 03Fauxbra
I was lookin at my diablo fuel tables... and when under full load.. im running at 96.4%. I know from experience you dont want to run over 85-90% load. So Is there anyway for me to get this changed? or would it have something to do with my tune. Im running a set of 39# injectors and a Cobra/Lightening MAF .. The car is putting down close to 270 hp. So i know im not pegging out the MAF or the Injectors.. (Which is overkill i know)
RE: Load % question
Posted: Tue Jan 06, 2009 5:05 pm
I'm thinking you are confusing load with injector duty cycle.
Add a blower or turbo to that can and you will see load go way over 100%!
RE: Load % question
Posted: Tue Jan 06, 2009 5:15 pm
by 03Fauxbra
So what does this load % mean if its not max fuel %
RE: Load % question
Posted: Tue Jan 06, 2009 5:16 pm
by sohfast94
Yes, please clarify..
Re: RE: Load % question
Posted: Tue Jan 06, 2009 5:21 pm
03Fauxbra wrote:So what does this load % mean if its not max fuel %
Most if not all of the fueling and timing tables in the PCM are based on load these days, since rpm is not enough considering the load on the motor changes as you increase speed, even at the same rpms.
RE: Re: RE: Load % question
Posted: Tue Jan 06, 2009 5:42 pm
by 03Fauxbra
so what is a safe operation max for a engine to handle before that is no longer a safe level?
Posted: Tue Jan 06, 2009 5:51 pm
It dont work like that...load is simply determined by certain things the PCM calculates, you will see as much load as the PCM calculates.
