Best MPG
Posted: Wed Jan 07, 2009 10:51 pm
by goosemanx
Which tune would provide the best MPG? 87 or the 91? Also i tow a camper alot in the summer time 2005 gmc sierra,4.8l u7193,v9r09
RE: Best MPG
Posted: Thu Jan 08, 2009 11:17 am
Mileage will be about the same between the two.
RE: Best MPG
Posted: Thu Jan 08, 2009 3:00 pm
by Poetique
Yep.
So by a cost standpoint the 87 should save you the most money, simply because it's a cheaper fuel.
RE: Best MPG
Posted: Thu Jan 08, 2009 10:36 pm
by CANUCKPREDATOR
91 octane will give you the best power for towing. i run 87 for daily driving and 91 when towing (usually a tank before a trip)
RE: Best MPG
Posted: Fri Jan 09, 2009 5:34 pm
by sickREDsierra
i use the 2x4 method for best mpg.
take a piece of 2x4, cut it to about 6" in length, and place it under the gas pedal. you can use untreated wood, since its cheaper.
works great!
RE: Best MPG
Posted: Tue Jan 13, 2009 9:45 pm
by keoni1978
I have a 08 Sierra Denali, so would the 87 tune give me the same MPG as the Diablo tune? Thanks
RE: Best MPG
Posted: Tue Jan 13, 2009 11:02 pm
by sceptre
using a HO engine, should you even being using 87 gas? I know it will run and retard the timiing to compensate, but lowest i've ever put in mine was 89.
I haven't been around here long enough to know what is in the 87 tune, but if the engine runs best on 91, wouldn't be hard to push more power out of it from 87? i may be WAAAYYY out in left field...someone please give me some info if I am
Re: RE: Best MPG
Posted: Wed Jan 14, 2009 10:44 am
sceptre wrote:using a HO engine, should you even being using 87 gas? I know it will run and retard the timiing to compensate, but lowest i've ever put in mine was 89.
We have developed tunes that allow you to safely run 87 octane fuel in these trucks while still increasing performance.
RE: Re: RE: Best MPG
Posted: Wed Jan 14, 2009 6:09 pm
by keoni1978
I guess I'll give the 87 tune a try and see what kind of MPGs I get. Thanks
