U7146 REVISION UPDATE RELEASED!
New Update 9R07 in the link below...
http://www.diablosport.com/index.php?mo ... lay&pid=14
This should fix many little quirks. We also added some adjustable parameter fixes and a few calids that were unsupported.
If you have any feedback feel free to post.
Enjoy!
Kevin@Diablo
Enjoy!
Kevin@Diablo
RE: U7146 REVISION UPDATE RELEASED!
Thanks MR kevin but what about the RPM issue
Also when i return the orginal backup to the car a lot of smoke will come out from the Exhaust but after drivin the car for a while the smoke will stop...
Wish to know how to solve this issues.
Wish you all the best
If the car is smoking heavily there is likely a mechanical issue somewhere.
ok, i will check it out
i am still happy with your product and your support
mrmustangman357
What exactly has changed with this revision? Is datalogging to pc in real time now supported? what other parameter adjustments have been added?
This update was to fix as many random issues as possible. We fixed some pinging and RPM limiting issues in the Mach1's. Fixed some of the adjustable parameters for tire/gear adjustments etc... Basicly if you were having any issues before no matter what model your Mustang is I recommend updating to this revision and see if your problems go away.
Realtime Datalogging with Dataviewer is something we are looking into for this tool but it will likely only work on the newer hardware.
Kevin@Diablo
Kevin@Diablo
mrmustangman357
I still don't understand why it would be beneficial to update to this revision. i don't have a mach 1 and my tire/gearing is just fine. Is there a new tuning strategy with the canned tune, or a fix for the datalogging? This has gone on for quite awhile with still unresolved issues. As you describe it, I dont think it is worth the effort to set my tune back to stock and get this rev downloaded and installed, unless there is a legitimate reason, other than. You understand my point?
99 cobra, intake and exhaust
carter242000
mrmustangman357
We made many changes that might not be visible or noticable to some. In the end this rev will be more stable and should show great results all across the board and eliminate most all the issues. This rev is another step towards realtime datalogging and 5 custom tune capability which I would like to add when we get to doing the next revision.
Kevin@Diablo
Kevin@Diablo
mrmustangman357
mrmustangman357
chaddict
