doesent load tcm file u7137
Posted: Tue Jan 20, 2009 4:48 pm
by ~RAM~
yea i got a custom file from johan awhile ago, an when i go to load the pcm file its fine an asks for back up an i do so.. but what about the tcm file? how do i get that to load..
RE: doesent load tcm file u7137
Posted: Wed Jan 21, 2009 8:11 pm
by gomangohemi
If you are not doing it under the advanced tuning tab, then do it there. Check the box to attach tcm file > add pcm file and it will ask will give you options for the orig. backup. It should locate the one you have. After that, it will ask you if you want to attach a tcm file. say yes and attach the file. it will then ask you to save the orig. tcm file. Do so. Then you should click send to tool.
Posted: Thu Jan 22, 2009 9:32 am
by johan
gomangohemi, where you able to load those files??? Without the vin mismatch error coming up?
Posted: Thu Jan 22, 2009 7:14 pm
by gomangohemi
johan wrote:gomangohemi, where you able to load those files??? Without the vin mismatch error coming up?
The first set you sent me, yes. But not the others.
just for clarity, they all load on the tool fine, I get the VIN mismatch after it's attached to the truck.
Posted: Sat Jan 24, 2009 8:30 am
by Hayabusa1
I had a similar issue Johan. I believe I finally got it correct, but is there a way to verify it?
