U7165 surging problem
Posted: Sun Jan 25, 2009 1:46 pm
by grumpy929
Alright let's try this again. My truck is a 2003 Ford Excursion 6.0 powerstroke. My predator is an U7165. v.9r05 Calid: VXAP2A2
The problem I am having is a surging at around 1750-2000 rpm (More annoying than anything) It is also throwing trouble code P2290 (Injector Control Pressure Too Low) when the tunes are installed.
Previously, I thought it might have been an injector problem. I had the dealer fix the injector issue. Installed tune when I returned from the dealer and had the same problems as before I took it to the dealer. So I put the truck back to stock tune (which of course immediatly dropped my fuel milage to about 13 MPG)
With the stock tune installed, I do not have any surging or any trouble codes. This leads me to believe that it is the predator causing the problem.
I would like to run the predator on my truck but, without the surging and code throwing. Any help would be greatly appreciated.
Thank You
RE: U7165 surging problem
Posted: Mon Jan 26, 2009 11:43 am
Is this with the 60 HP tune, 100 HP?
Posted: Mon Jan 26, 2009 1:06 pm
by grumpy929
100 Hp tune
Posted: Mon Jan 26, 2009 1:20 pm
by sohfast94
Unfortunately the code thing might be there although if you posty your last tune wirtten I might be able to fix the surging for you.
Posted: Mon Jan 26, 2009 1:50 pm
by grumpy929
File should be attached
Posted: Mon Jan 26, 2009 1:52 pm
by grumpy929
Posted: Mon Jan 26, 2009 1:56 pm
by sohfast94
Try this... and make sure you get back to me on any changes so I can track this issue.
Posted: Mon Jan 26, 2009 2:31 pm
by grumpy929
Seems to have smoothed out the surge. No trouble codes were thrown. I will drive it for a day or two and post how it does. Thanks
Posted: Mon Jan 26, 2009 4:08 pm
by sohfast94
No problem man. anytime.. If it solves the problem I will release a new rev to make sure everyone gets the same...
Posted: Wed Jan 28, 2009 2:54 am
by powerstroke41
I have the surging prob right before i come to a complete stop.
Posted: Wed Jan 28, 2009 3:00 am
by powerstroke41
how much will a trinity retail for and when will it be avail. for a 2006 f250 powerstroke 6.0
Posted: Wed Jan 28, 2009 11:04 am
$799, should be available in a couple weeks.
Posted: Thu Jan 29, 2009 10:34 am
by grumpy929
The new tune seems to have fixed the surging issue. I am still a little concerned about the trouble code (P2290) that appears from time to time. Other than that, it seems to be a good tune.
