KPA to PSI???
Posted: Tue Jan 27, 2009 11:01 am
by sfla_srt4
how do you convert the KPA reading to a PSI reading?? The map is shown in the KPA form and im trying to figure out how to read it as PSI.. Thanks!
RE: KPA to PSI???
Posted: Tue Jan 27, 2009 11:03 am
http://www.csgnetwork.com/presskpapsicvt.html
To convert kilopascals to pounds per square inch, multiply the kpa value by .14503773773020923
RE: KPA to PSI???
Posted: Tue Jan 27, 2009 11:35 am
by sfla_srt4
Then the values are wrong on the trinity... When I put the boost gauge around "0", it says ~100Kpa... Could you guys look this up to see? When im crusing on the highway, its around ~65Kpa, and im in vac, deffentily not 9lbs of boost lol..
RE: KPA to PSI???
Posted: Tue Jan 27, 2009 11:51 am
0 Boost is atmospheric pressure, which is 14.7 psi....so, 100kpa x .1450377=14.50377, right about 14.7 psi which is atmospheric...
RE: KPA to PSI???
Posted: Tue Jan 27, 2009 1:11 pm
by sfla_srt4
ahhhhh thanks then.. Forgot about the baro.
Posted: Wed Feb 11, 2009 4:42 pm
by parsonsproject
So is there a way, using MAP kPa, baro, and whatever other readings, to get a value in psi which is the actual psi being sent into the manifold? Is there another value to log which I am missing? My obd2 aeroforce interceptor scangauge is able to do it.
04 neon srt-4
Posted: Thu Feb 12, 2009 12:21 pm
by ChrisMyers1
Is this possibly a dodge related issue showing atmospheric?
Posted: Thu Feb 12, 2009 12:26 pm
Yeah, it is simply the way the factory PID works.
I was logging our Duramax this weekend and it shows actual PSI with 0 being atmospheric.
