well, you're asking for big trouble by just jackin' everything up like that, especially the timing...
and if your long term fuel trims are up in the +15 range, you're running way too lean!
get some good numbers man... you want your LTFT's to be between 0 to -2....
here's info on how to drive properly to see what your LTFT's are at:
you can't save logs as we know, but you can watch the data live on the screen while you drive...
see what the ltft's are reading when you're driving steady at about 2000 rpm on the highway...
you need to go the opposite way on slope adjustment compared to your ltft readings...
for example, if your average ltft's are at +6.xx, then you need to adjust your injector slope to -6%...
and after making an injector slope adjustment, you need to drive for about 50 miles to let the new setting get relearned by the PCM... if you try to check the data again right after the adjustment, the numbers won't be correct, because the new setting hasn't even gotten relearned and settled in by the PCM yet..
