Hello,
I have a ABU2 processor in a Lightning. I am running into a situation where it will not allow a value higher than 64LB/min in the MAF curve. Is there a way around this in the software?
ABU2 Lightning processor
RE: ABU2 Lightning processor
You have to ratio the injector hi and lo slope, breakpoint and displacement scalar equally to deal with this issue. For example if you install a MAFia on setting 2 you will need to multiply the above mentioned by .76 and continue to tune. Depending on the combination .76 will get you in the ballpark. If you go bigger on the maf you'll need to reduce them even more...
Kev
Kev
RE: No Mafia
Thats the problem, it will not let you go beyond that value.
You will need a Mafia.
