Thinking of U7180 What live data can be monitored ??
Posted: Sat Feb 03, 2007 3:45 pm
by Danbeck
Thinking of buying a U7180 for my 01 LB7 duramax. I'm wondering if the fuel line vacumn for filter fuel flow can be monitored? Also can EGT and boost be monitored live? The new 2 micron Gm filter can plug pretty quicklly I know the dealer can read a value. They said mine was at 5 and should be replaced, I guess a fresh filter is about 2. Sure would like to read this value myself! Also not like to purchase EGT guage if I could get this information from Predator! I have looked on this site for a listing of what information the Predator would provide me. But unable to find the link ! Thanks,,,,Dan !
RE: Thinking of U7180 What live data can be monitored ??
Posted: Sat Feb 03, 2007 4:51 pm
The PCM does not monitor EGT, so that value cannot be displayed on the Predator.
I will look into the other parameters you asked about on Monday and let you know.
Posted: Mon Feb 05, 2007 5:14 pm
by Danbeck
Bump ! :lol:
Posted: Mon Feb 05, 2007 5:33 pm
Good bump! Gimme a minute...
Posted: Tue Feb 06, 2007 12:24 am
Sorry, got busy again today.... I will hilite this thread and get you an answer first thing in the AM.
Posted: Tue Feb 06, 2007 10:51 am
This seemed like an easy enough question....but I do not have a Duramax here right now to look at the live data. We are trying to determine if this is a special function of the TechII (dealer tool) or a standard parameter that the Predator can see.
I will let you know as soon as I find out.
Posted: Thu Feb 08, 2007 4:28 pm
by johan
I just went through the Tech2 on our duramax and there is nowhere to check fuel filter status, only oil filter life, but no fuel filter.
Posted: Fri Feb 23, 2007 6:00 am
by Arcing
The dealer checks the vacuum at the fuel port (black plastic covered brass schrader valve) directly above air conditioning pump. 2Hg for a fresh filter and full tank, at 5 to 7Hg they replace. So it's not monitored electronically. There are Vacuum/pressure testers available that fit that particular connection.
Posted: Fri Feb 23, 2007 9:46 am
Arcing wrote:The dealer checks the vacuum at the fuel port (black plastic covered brass schrader valve) directly above air conditioning pump. 2Hg for a fresh filter and full tank, at 5 to 7Hg they replace. So it's not monitored electronically. There are Vacuum/pressure testers available that fit that particular connection.
Thanks for the input!
